Quick and dirty 4-jaw set-up
  • Quick and dirty 4-jaw set-up
    Hey all,
    I don't do much work with the 4-jaw chuck so any kind of "cheat" helps me.
    I use a little jig to hold a stack of fiber washers while drilling the hole out from 1/4" to 3/8". It works (worked) great until I ran out of the large quantity of washers I'd been using finally, and started on a new batch.
    The new ones are a few thou bigger than the old ones so I decided to enlarge the hole in the jig. I used a steel ball bearing that I've had hanging around for years and seated it in the hole while being held in place by the tailstock chuck. I brought the jaws into position while rotating it to make sure I was staying in contact with the tailstock chuck and....ta-daaa.
    I'm sure it's old news or common sense for most, but for me, this Q&D method saved me some time and probable frustration so maybe it'll help someone else.
    Thanks for looking!
    John
    Good thinking, if quick and derty works do it.
    jcon
      In stead of the 3 jaw chuck, a center with a hollow cone (I forget what
      those are called) would be even easier and maybe more accurate.
      That is very good if there is already a hole in the work.
      ...Lew...
        Thanks guys...that's a good thought Lew.
        John
