E-mail question?
  • E-mail question?
    From titme tot time I get an e-mail from someone and the font size is tiny,to small to read comfortably,is there a way to inlarge it?
    I have tried to highlight and change the font,but no dice.
    f11 on your keyboard will give you "full screen" A friend came home from a tradeshow with gifts for all of his buddies. He called
    it a "penis enlarger"! Really a 4 power magnifing glass. Might change monitor resoulition on monitor too. Good Luck.
      Sir:
      I had the same problem: go to View, Text Size, and select a Larger. That works!
      Regards,
      Jack C.
        Wierd, If you have a wheel mouse, hold down control key and wheel back for bigger, front for smaller. Works in most places, don't know about your e-mail, but it is worth a try. James
          Thanks for the help,all of the above worked!
