drill jig
  • drill jig
    This is the 3rd version of a jig I made to drill hole in the center of a shaft.
    irnsrgn
    Necessity is the mother of Invention
    I like your wing nut. Is that a "V" block under the shaft?
    [This message has been edited by G.A. Ewen (edited 02-27-2004).]
      yes its a V-block, second version had hex nuts and needed a wrench to tighten, there is a keyway cut in both pieces and a key inserted to hold the upright in position. Wingnut and knurled nut made it wrench free except for changing the drill bushing with an allen wrench.
      irnsrgn
