Link belt Mower Deck
  • Link belt Mower Deck
    Is a link belt a good/bad idea for a mower deck?
    Link Belt
    The link belt probably can't hold up to that kind of rough service. If you need extra flexibility you might think about a V belt with notches on the inside.
      Link-Belt is in the business of manufacturing heavier equipment, cranes , etc. I wasn't aware of a mower deck. My experience is that there equipment is top of the line and first class.
      I don't think you can go wrong with Link-belt equipment, it will probably last a lifetime.
        Toolguy may be more educated or experienced on this subject than I, however if you look at Fenner Drive's web site http://www.fennerdrives.com/high_per...FQSxnQodbEwj9g you will find more specific information. Apparently these belts are used on some pretty heavy stuff. They even advertise they replace "Any Belt Any Time".
          If your'e talking about the "Link-Belt" that we use on power tools/machines, no, don't use that, it will not stand up to the strain , reverse bends, dirt, crap etc.
          Buy the industrial belt they sell for that application, here the brand is "Gates" and the belts are a green colour. Good belts.
            The backside would be hell on the idler pulleys, or vice versa.
              Tried it..
              Bad idea, Belt soon got destroyed. Seemed like a good idea but was not.Regards David Powell.
                Forgot to mention those belts have a unmarked rotation to run.
                The inside "Tabs" must be able to fold down around inside corners.
                  In reality, those are "emergency" or low stress application belts only, so you need to use a bit of common sense when installing them. They might last forever, or they might last 5 minutes. If the belt on your mower or lathe breaks, no biggie. You arent stuck anywhere and likely havent destroyed anything. If you install one on a vehicle, it breaks and does damage, youre stuck going for a walk, paying an expensive bill, and if the dealer sees it you will lose your warranty on a new vehicle.
                  The military has had them for 30+ years now as a "one size fits all" emergency belt for vehicles. I installed and later deinstalled a few hundred of them when I was still enlisted.
                    Fenner
                    FYI. I called Fenner and the tech said, emphatically, "no"....not recommended for that. Thanks for all the replies!
