do boring bars need hardening?
  • #61
    A real pretty girl can make your boring bar hard.
    • #62
      I knew there was a reason I hadn't clicked on this thread earlier!
      I don't even know what is being heatedly argued over at this point, but it seems to center around the certain term "resilience". As such, I will add the following as it hasn't been mentioned yet:
      resilience. (1) The amount of energy per unit volume released on unloading. (2) The capacity of a material, by virtue of high yield strength and low elastic modulus, to exhibit considerable elastic recovery on release of load.
      p.48 Metals Handbook Desk Edition (2nd ed.). (1998). Materials Park, OH: ASM International.
      If there will be a discussion, there must be an agreed upon definition and, preferably, one that is quantifiable. Otherwise, we can turn circles all day over what is "hot" and what is "cold." The reference above is the most authoritative one I have access to. The yield strengths for the two alloys are listed as follows:
      ANSI No. 1020, cold drawn. Yield Strength = 350 MPa / 51 ksi
      ANSI No. 4130, Water quenched from 855°C and tempered at 540°C. Yield Strength = 979 MPa / 142 ksi
      p.154, 156. "
      The Modulus of Elasticity for both is constant. Given this information, I tend to follow this line of thought: For a given material, "resilience" as defined above is a ratio of "high yield strength" to "low elastic modulus." Given that the elastic modulus is constant with these two examples, a higher yield strength would be defined as having more resilience.
      Okay. So what does that matter? I guess it means that the heat-treated 4130 bar will take more stress* before being permanently deformed (changing shape). "Stress" here is being defined as, the intensity of the internally distributed forces or components of forces that resist a change in...shape of a material that is or has been subjected to external forces. p.56. " In other words, the strenth of the boring bar to "push back" before permanently changing its shape.
      The KEY to remember here is that this has NOTHING to do with the deformation characteristic of the bar BELOW the yield strength. Both bars perform identically in this regard (Modulus of Elasticity). It only means that the point at which your boring bar is ruined from a big oopsie takes a bit more force than the non-heat-treated material.
      I guess? I'm no metallurgist. Heck, I'm no "machinist!" I am just a guy that is trying to sort through the confusion in this thread with the available reference material on my shelf, a little logic and about two hours into it. I hope my "proof" was clear, correct and at least helped someone rather than fuel the argument
      • #63
        This comes up so many times and is beat to death in each thread that at some point I just have to put a little humor in it.
        • #64
          I just had to look at this thread to see how a simple question "do boring bars need hardening? " could run to 7 pages when the answer to the question is "No, they don't need hardening""
          "Patriotism is the last refuge of a scoundrel"
          • #65
            The AISI 1020 is a red herring, IMHO, since mild steel's properties don't change substantially through heat treat.
            Evan's original point was that the tensile and yield strength of an alloy boring bar increases via heat treat, but that's probably not desirable considering that a chromoly boring bar has vastly higher yield strength than the grey cast iron that comprises your topslide. You know all those lathes you've seen with the tool slot busted out?
            That said, heat treating to resist screw bite marks and swarf flow is certainly desirable in a pro shop, probably less so in a home shop.
            • #66
              p.154, 156. "
              Thanks Arther, very well written I might add
              But the sad thing is is it most probably will fall on deaf ears...
              appreciate the time - don't feel bad, I bet I got more in than you
              • #67
                so don't heat treat neither of them and compare yield strength -- im not ascared
                Actually that wasn't his original point -- it was my point to point that out to him.
                Any other questions?
                • #68
                  Originally posted by flathead4
                  They might have well said it was "wholesome."
                  Ha!
                  Tom
                  Really? are you reading any of this? what planet do you live on - Hostess?
                  is any switch being flicked at all? - a dim bulb? some kind of spark? are you getting anything from any of this yet?
                  • #69
                    "Is this the right place for an argument?"
                    • #70
                      Your missing my point about why that's a red herring
                      Mild steel has a yield strength of ~ 60 Kpsi, whether it's hardened or not. 4140 is 50% stronger than mild steel when annealed (95K yield strength), and wildly stronger when quenched and tempered (240K yield strength).
                      But even mild steel is 50% stronger than Class 40 Grey -- you'd be better off with a cast iron boring bar and a steel top-slide
                      Sorry AK -- it;s tough wading through the pissing contest
                      • #71
                        The argument is fun but the personal attacks are tiring.
                        Tom
                        P.S. - I just noticed your quotes. Perfect.
                        Tom - Spotsylvania, VA
                        • #72
                          As I said earlier - I buy my boring bars and clamps (as a set) new and whatever material they are made of does the job. If the boring is not satisfactory then I reduce speed and/or feed or re-grind the boring tool or re-think or re-adjust the set-up.
                          "Stiffness" and "rigidity" are not restricted to the boring bar but to machine stiffness and set-up - to mention a few.
                          If I need to make a boring bar I use plain old cold (or hot) rolled mild steel. I prefer round HSS stock as all I need are round holes - no square ones.
                          On occassion I will MIG or silver braze a tool to a boring bar.
                          I have a quite good but "light" lathe is so I neither push it to its limits nor do I try.
                          I have plenty of time and my "tear-ar$ing" days are long gone and they are not coming back
                          • #73
                            Sorry Flathead just trying to get through
                            did maybe all this talk make resilience sound better than "wholesome" lol
                            I could say you like to waste peoples time - but then it would be noticed that I have time to waste...
                            • #74
                              Lazlo I think im seeing your point on it being a apples to oranges comparison ----- so just take annealed 4130 and put it up against heat treated 4130,
                              The heat treated is both more durable and resilient. It has a higher yield strength...
                              Don't be sorry - just realize that I generally don't have pissing contests all by myself -- I mean I may get a little lonely sometimes but I draw the line there...
                              • #75
                                Now this is one of those posts that's heading for a lock if for nothing more than AK likes to hear echo's
