do boring bars need hardening?
  • #76
    +1
    This seems to be one our annual "storm in a tea cup" threads with a lot of people talking at but not to each other.
    http://www.google.com.au/search?hl=e....0.mBgGchfARBc
    • #77
      I would like to use this thread to express my opinions of others as well.
      • #78
        Quite some others seem to be using it as a vehicle to have a shot at or to try to shred some others.
        There is any amount of precedence for you to join in.
        For what its worth, the OP's heading is:
        the text for which is:
        Originally posted by lowcountrycamo
        Making a couple of 3/4" boring bars out of hardened rod. Annealing now. Should I re-harden after machining. Bars will be 10" and 6". Thanks.
        It seems to be a simple question that after all the number of times that this thread has been hashed around over time that there should easily be a short concenus answer without any of the "side issues".
        • #79
          I have made a couple from annealed torsion bars , machined the pockets and cleaned the body back to give some clearence and then just hardened the first 50-70 mm so that the inserts dont chew the pockets out and to reduce the wear that Sir John described .
          These are about 250mm long and 19mm diameter.
          They should outlast me as they only get 8-12 hours use every six months.
          No pics as they are packed away waiting for the next job.
          Michael
          • #80
            I made these little bars out of 12L15. I don't think you can really harden that material. They work fine as long as you don't try to take too heavy of a cut. If I had made these out of any other material they would have never come out as nice as they did...... insert pocket and 4-40 screw hole would have been tough to cut.
            JL....................
