Wheel stud material
  • Wheel stud material
    Anyone know what a good material is for a wheel stud? This is for a small trailer for a motorcycle fwiw.
    You might try: 4130 or 4140
      1090,1095,4140,8620.
      Did you get a Thread rolling head your not telling us about ?
        A friend needs a replacement and can't find one. I'm entertaining the idea of making one but it needs to pass the "this is a stupid idea" test, first
          I just bought one for a Dodge van after a tire store ruined one somehow. A universal from a parts store wasn't available It was over $.12.00 from Chrysler so I'm thinking they must be made from platinum.
            How about machining a stud from a grade 8 bolt. I suspect that common or garden variety studs on cars are not any stronger than a grade 8 bolt, With luck you might even get one end already threaded!
            Duffy, Gatineau, Quebec
              Try Dorman...you find Dormans part number..you can order from Autozone, Advance Auto etc...they supply studs to an SAE Gr. 8 standard.....
              Www.dormanproducts.com
                Crack open a cold one and yell, "hey y'all, watch this" first.
                  Given the fact that rolled threads are 30-40% stronger than cut ones it's kinda of a bad idea right out the box.
                  If you have a local old time parts house nearby like a Napa or Car quest store your best bet is finding something close,same thread but bigger knurl and reaming the hub to fit.
                    you can get a whole new hub at wally world for cheap. Any place that carries trailer parts will have them also
                    Craftsman 101.07403
                    Grizzly G0704
                    4x6 Bandsaw
                      Good gnuz is he just needed a shoulder turned down a bit. I've replaced a bizillion studs over the years but never had to make one and that's just one of the kinds of things I don't care to make, given the risks.
