What is this pan for?
It also appears similar to a pan i have for melting wiffle rods that are used to harden muffler bearings.
Guest repliedNaw its the oil tank for the military version of a hydraulic attachment for the rudder on a duck's tail.
How about a bed pan -for "Solids" and liquids, the handle could be the pouring spout to empty it.
We're all way way off... it's going to be something on the order of a shoe-sole bitumen-application unit, or a specialized Kentucky Hot Brown broiler or even a peroxide-fueled rocket-torpedo impact fuze adjusting wrench.
Awww, now maybe we will get an answer, that's what we need for this , someone who is up on antiques.
No good guesses, but you may want to try sending a few photos to this guy:
I've been collecting unusual tools and other objects for quite a while, and several years ago I started this project of posting them on the web as puzzles for visitors to figure out what they are.
He post tons of stuff like this and gets lots of responses. You can waste a considerable amount of time looking through the stuff he posts.
Originally posted by topctYes. And the round thing is a vacuum motor to open and close a door in the snout. It would allow for circulating warm air from an exhaust manifold.
No -------- it's an oil bath filter - but kinda like the scarecrow its just missing its straw,,, (or brains or something like that)
the roller is indeed a float - it's to tell you when the filters running low on oil...
Your cruel dude ----- and u made me waste some very high dollar IPA out of my snout
Count me in among the 'tape/stamp licker' crowd except I suggest it was intended to apply hot water for the old 'horse foot' glues.
The might have been a sponge in the round hole for 'licking' single stamps rather than getting them stuck to the roller.
Guest repliedYou need to buy it and take it to the next Antiques Road Show. Probably worth tens of thousands of dollars.
Originally posted by aboard_epsilonit's an air filter cover .off a small engine
all the best.masrkj
Originally posted by lugnutI think we are getting close. If my memory serves me correct, back in the early days of "Packing Tape" the paper tape had a glue on it that had to be moistened before applied. If this pan was full of water and the tape drawn across the roller, the wet roller would moisten the tape, the excess water would return to the pan through the small holes. The large hole for viewing water level and refilling. Beat the heck out of licking 20 ft. of nasty tasting tape.
The pan makes me think it was an applicator for something that would be melted which was added through the large hole. Once melted, running your paddle (or whatever) back and forth on the roller would automatically apply the stuff to it and the excess would fall to the pan and drain back into the bottom through the small holes. Having a "top" like that on it would give some protection to keeping the melted product from slopping out and give it some protection from junk falling directly into it plus having the top solidly joined to the bottom would eliminate any chance of it getting lost. One possibility...could it have been used to apply tallow to paddles used for shaping lead body panel filler back in the old days before "Bondo"?
all the best.markj
sospan fach !Last edited by aboard_epsilon; 07-06-2012, 06:41 PM.
Yeah, probably used for moistening those nasty single rows of S&H Green Stamps that one got when your grocery purchase wasn't very large! I imagine the price would have been 1-3/4 books.
Note: Anyone under 40 probably will not understand this post!
.Last edited by Mike Burdick; 07-06-2012, 03:27 PM.
No - pretty sure it's a pan,, But could be used like you said - in conjunction with something else, - all this talk of tape and such has made me wonder if it's not one part of a two part system --- Like you set it (and kind of align it) under a few rollers on a stand that the tape or whatever is in and you just pull the tape and it guides it over the pan and single pan roller
maybe...Last edited by A.K. Boomer; 07-06-2012, 02:57 PM.
Are we SURE it's a pan and not part of (say) a boiler or a furnace or perhaps some kind of obscure blacksmith tool?
Just throwing that out there, we could be assuming the wrong things about it.
