OT: Dell computers
  • OT: Dell computers
    A recent recepient of a Dell D600 laptop, and using a friends desktop, it's apparent that Windows software is slightly "different." Even looking on ebay there is stuff for "Dell" apart from just plain Windows.
    Any explanation?
    gvasale
    All computer manufactures have the abilty to custumize windows for there brand.Dell just goes farther than others.
    Craftsman 101.07403
    Grizzly G0704
    4x6 Bandsaw
      So, as an example, the "search" feature doesn't show up when you click on the "start" icon. So if I just got a new xp disc and load that, will things operate as I'm accustomed? (just one illustration)
      gvasale
        You can right click on the start button select properties and you can add the serch to it and what ever else you want. You do not need to reload windows.
        Craftsman 101.07403
        Grizzly G0704
        4x6 Bandsaw
          The search feature option is customizeable under Start menu->customise...and you get to it by rightclicking the start button.
          Chances are..if your pc/laptop runs windows7.. you may have difficulty finding xp drivers for the newer hardware.(and before you delete win7 or vista..you need try to locate all the drivers you'll need).
          Rob
            Everything in Windows is highly customizable by using the Group Policy Editor. I will not explain here how to go about that because you can easily cause massive problems. Virtually every single part of Windows can be enabled, disabled or otherwise changed using the GPE.
            The GPE also allows you to turn off some of the most annoying features in Windows including any and all sections that "phone home" automatically.
              This is just a small part of the total settings available. At the admin level there are something like 1500 entries each with various settings or combinations of settings.
                Dell OEM Windows uses a special OEM SLP key and OEM BIOS Flag for activation of the OS. You can't use the Dell OEM Windows on a different PC.
                  Thanks to all. I got the search on the startup now, I'll look into other stuff later.
                  gvasale
                    Evan,
                    You said:
                    "The GPE also allows you to turn off some of the most annoying features in Windows including any and all sections that "phone home" automatically."
                    Can you tell me which part of the GPE relates to the "phone home" functions - I would like to look into this.
                    Ian.
                      That's not just Dell, it's how all OEM copies of windows are activated. Windows 7 uses SLIC 2.1. You can get a little program that takes a BIOS update file for your computer and adds the SLIC 2.1 table to it. You choose Dell, HP, Asus, etc. Add matching SLP & certificate to windows installation and it's done.
                      This info has been supplied for educational purposes only
                      Ed
                        Slick! That took some serious sleuthing...
