insulating value of ping pong balls
  • insulating value of ping pong balls
    Pretty obviously OT I have an idea to use a layer of ping pong balls arranged in one layer and all touching, then fill the gaps with insulating foam, then skinning it over with fiberglass on both sides. It would form a panel which would be strong, yet light, and have some insulative value. I'm wondering which part would insulate best, the spray-can foam or the balls. Being hollow and air-filled, there might be an air current set up inside in response to temperature differentials from one side to the other. If that happens, the ball would be a poor insulator. If perchance that wouldn't happen, then it would be a good insulator, and the foam would go three times as far. Ping pong balls are about 1-1/2 inches in diameter, and as smooth on the inside as they are on the outside.
    It has occurred to me that you could lay a lot of them on glass and glue them to each other- that would give a flat base for the rest of the panel to be formed onto. Or- you could arrange them to make a shaped panel, or a corner.
    For practical purposes this may all be quite insane- or it may have some value in some way. It's just an idea that came to me while looking through a dollar store and seeing boxes of ping pong balls cheap.
    The first thing I wonder is if a given temperature change or quickness of change would collapse the ping pong balls?
    Not that it would matter if all of the gaps were filled with insulating foam or that you could do anything about it anyway but what about if that happened to a number of them in terms of structural integrity?
    I'm envisioning large insulating panels that if a line of balls caved in could kink the panel...
      Air is a great insulator, especially insulated air. I don't know which would have the greater R value but it's my experience that "insulation" and air pockets work best together as you are doing. And I think it's a good idea as long as the balls are real cheap.
        Darryl , do you have an application in mind for this??
          Sounds like a lot of extra time and trouble when you could just use sheet styrofoam. Small air bubbles are better than big air bubbles because of convection cells in large bubbles. Ping pong balls are just big enough for convection cells using dry air. Dry air can form convection cells down to a sphere of about 3/4" diameter. Below that convection stops operating and only conduction and radiation play a part.
            Float a bunch on your heated swim pool to help contain the warmth. Might make an interesting swim if left in place. Might foul up the skimmer tho. Oh well.
            Jim
              If all you want to end up with is a lightweight insulating panel with a fibreglass skin on each side, while your pingpong balls and sprayfoam idea will work, it will be a lot easier to obtain a slab of foam, either EPS or rigid PUR and fibreglass that, be careful with you choice of resins though. Polyester resins (cheapish) will dissolve EPS foams but are AOK with PUR. Epoxy resins (dearer) will be OK with either type of foam.
                A layer of aluminum foil anywhere in an insulating layer adds R3 to the insulator.
                  First off, I don't think the balls will even feel a change in air pressure, up or down, since the round shape would support either without difficulty. If you physically crushed an area- well there would be support from the foam, plus the fiberglass skin.
                  The balls are cheap, otherwise the cost per sq ft of panel would be too high. As it is it would be about $2/sq ft for the balls. Contrast that with a foam that won't dissolve with polyester resin, and the balls come out a lot less expensive, even when you add in the cost of spray foam. Polyester resin compatible foam is not cheap by a long shot, whether bought by the board or in a can. EPS or styrofoam is a lot cheaper, but then you contrast that with the extra cost of epoxy resin- then you consider the fact that epoxy isn't designed to 'soften up' fiberglass matte, so you want to stay with polyester resin-
                  It was just an idea. Evan, I think you're right on the mark with the comment about the maximum size of cell that would be useful- the balls are too large to prevent convection.
                  I don't have a particular application in mind, though it's not hard to see that a light and rigid panel would have advantages, including having some insulative value. A body for a one-man electric runabout, perhaps- maybe the bottom part of a canoe could be built this way-
                    ummm, excuse me? But regulation ping pong balls are now 40mm diameter. I just felt like correcting somebody on the internet.
                      Dang! No wonder these balls are cheap- out of spec!
                        My suspicion is that better R-value insulation could be obtained in a somewhat thinner panel without the ping-pong balls. Overall cost is likely to be lower as well, since there is no need to "herd" the balls and carefully spread out the expanding foam between them.
                        If you want a better material, still using a "wasted resource", you could do about the same thing with discarded "packing peanuts". It would be a good form of recycling.
                        1.5" is 38.1 mm 40 mm is 1.57"...... still "about" 1.5"
                        Perhaps a difference without a distinction?
                          Well, back when regulation balls were 38mm, I wouldn't have bothered correcting somebody over the .1 mm, but now their error is a whole 2mm!
                          If you've trained all your life on the 38mm ball, and somebody suddenly gave you a 40mm ball, it would feel like swatting a beach ball around.
                            I'm confused. Laid out perfectly you are looking at about 60 x 30 or 1800 ping pong balls. At a regulation weight of 2.7 grams each that's about 10.7 lbs. Not counting the weight of the foam or fiberglass matrix. The cost of the ping pong balls alone is $2 / sq ft. Not counting the spray foam, fiberglass, resin or ungodly amount of labor involved.
                            A sheet of 2" XPS foam is under $1 / sq ft and weighs about 8 lbs. It's a little heavier if you want the higher density sheets that will support up to 100 PSI (continuous rating is less).
                            There must be a reason why no one makes insulation boards out of ping pong balls but I can't think of what the reason might be.
                              I was just in a building supply store this AM. 2 inch xps is $37 for a 2ftx8ft piece. That's about on par with the balls, so why would I go the labor intensive route instead of using already formed sheet- there is no good reason I can think of at the moment.
                              In fact I can't think of any other use for ping pong balls except as- ping pong balls.
