Dial indicator recommendation sought
  • Dial indicator recommendation sought
    I'm a clock repair hobbyist, and a newbie to machining. I'm in need of a dial indicator to use with my Rivett watchmaker's lathe for the purpose of evaluating TIR of my collet assortment. After cobbling together a workable arrangement with a magnetic base on the lathe bed, I'm realizing that the most efficient use of my available tools would be to mount a dial indicator in the quill of my compound sliderest, since it's moveable along the X, Y and Z axis (the Z axis, "up & down", is moveable due to the brilliant design of the off-center hole in the quill which is rotated within the quill barrel).
    I'm having a hard time finding a suitable dial indicator that incorporates all the features I need, and I'd like to ask you guys for a recommendation or two. The dial indicator I'm seeking MUST have all of the following specs:
    1. High quality - no cheapie crap.
    2. Back plunger style with small contact ball.
    3. Half-thousandths resolution (0.0005"). All I can find on the internet seems to be 0.001" for the finest resolution on the dials.
    4. 0 - whatever - 0 for the dial layout (I don't know the correct terminology, sorry). I want a zero point in the middle, with "whatever" maximum on the left and right.
    5. Mounting post either 1/4" or 3/16" diameter. I'd rather have 3/16" because that's the measurement of my quill's bore, but I also have an alternate quill with 1/4" bore.
    Can anyone point me to an indicator with the above specs? Thanks in advance.......
    Doug Haeussler
    NAWCC #0167553
    My clock & watch collection website:
    http://dougsclocks.hpage.com/
    Try Mitutoyo they will fit the bill,there are plenty used in good condition on ebay.or new at high costAlistair
      Suggest you look at the Mutitoyo 2961F back-plunger .0005 dti, there's one on ebay and a number of links on Google....the one on ebay claims to be new in box....
        Although they are not plunge back I suggest you also consider dial test indicators (DTI's). Brown & Sharpe make excellent ones as does Interapid & Mutitoyo. Examples can be found at http://www.travers.com/skulist.asp?r...evel3+id+29629
        and http://www.travers.com/skulist.asp?r...evel3+id+29629
          Another vote for the Mitutoyo -- I have three, and I haven't killed one yet
          Brown & Sharpe/Tesa also make a fantastic dial indicator. You can find both for cheap on Ebay, but I strongly suggest you look for New In Box -- too many shysters with use metrology gear.
            Thanks guys. Video Man, thanks for the tip. The Mitutoyo 2961F looks pretty good to me (I'm currently using a DTI, and I specifically want to switch over to a back-plunging indicator). One question about the Mitutoyo 2961F.... where does the mounting post go? I don't see one attached, so I'm assuming it's separate. Does it screw onto the indicator's body?
            Doug Haeussler
            NAWCC #0167553
              I believe the mounting stem surrounds the plunger, or that's how the Mitutoyo back plungers work that I have seen. Stem is probably .375". I have not used this particular indicator....
                You dont want an dial indicator, you want a Test Indicator.
                Way more useful. I have rarely used a regular dial travel indicator when I got DTI's.
                http://www.google.com/#hl=en&gs_nf=1...w=1558&bih=832
                  READ the OP. He says he wants a back plunger style indicator. He doesn't say why, but does say that is what he wants. While I agree that I would use a Compac dial test indicator He seems to know what he wants or at least thinks he does. He may have a very valid reason.
                    I dont know my butt from a whole in the ground on clockworks,but thought id throw it out there. I havea back plunger one that has an attachment that also works like an interipid dial indicater. Dont think it measures to the accuracy you need though,ill have to check. I do not know if these are thest of both worlds or not,just tryin to help. I also had to hand polish the back plunger cause it was not as smooth as i felt it should be for the attachment part to slide across smoothly.
                      Lufkin made a back plunger ( model 299 and 399) that also can be used as a test indicator, only reads in 0.001" though. I have the Lufkin 299 and a Starrett 196 and it's very rare that I find them to be very useful.
                        Harvey i think i agree with you,everytime i think i find a use for it,i always end up going back to my starret last word indicator. Antique but shes beautiful piece of work. But since he wants the back plunger i thought id throw it out there,and i think your right on the accuracy range also.
                          Thanks for jumping in, everyone. I guess I should clarify a couple of things. My main field is collecting & repairing antique clocks. But I'm trying to acquire some knowledge of basic machining, because often I find that clock repair involves fabricating replacement parts. So I've got a way to go in learning the terminology appropriate for this forum.
                          What I'm seeking is one of these things, whatever they're called:
                          [IMG][/IMG]
                          It's a cheapie (Central). I want to find one of the above indicators (it's called a dial indicator, right?) with a 0-10-0 or 0-20-0 measuring range; I need the dial's increments to be marked in half-thousandths (0.0005") because my tolerances are pretty tight. The contact point should be a little ball tip instead of a convex disc, and ideally I'd like the mounting post to be 3/16" ind diameter, although I could deal with 1/4". If the 1/4" post is detachable, I can turn it down to 1/4". Otherwise I can fabricate an alternate quill (the stock one in my Rivett watchmaker's lathe has a 3/16" bore.
                          Here's a pic of my sliderest's quill, where I propose to place the indicator (whatever it's called). This pic is of my better-condition sliderest, I have two of them:
                          [IMG][/IMG]
                          Here's how I'm currently performing my current task, which is evaluating my collet collection for concentricity:
                          [IMG][/IMG]
                          As you can see above, my Mitutoyo DTI is mounted via a magnetic base to the bottom slide. That lets me draw the whole thing along one axis. So I just thought if I had an indicator like I'm imagining then I could just stick the indcator's post in the slidrest quill. Bingo, no magnetic base needed! And all of a sudden I could easily draw the measuring tip toward me/away from me, left/right and also up/down by rotating the quill (the bore is off-center, allowing slight height adjustments...a brilliant design idea from Edward Rivett).
                          Does an indicator like what I'm seeking exist anywhere at all?
                          Thanks,
                          ...Doug
                          Doug Haeussler
                          NAWCC #0167553
                            Goggle Long Island Indicator, they have comparisons about indicators.
                            Southwestern Ontario. Canada
                              Not quite a solution for you, but Starrett makes an adapter that allows you to use 4-48 dial indicator tips on their back plunger indicator. Starrett item # 196R. Starrett back plungers only go to 0.001 AFAK.
                              http://www.mcmaster.com/#catalog/118/2280/=il9dbl
                              My back plungers also have removable stems, so they could be turned down from 1/4 to 3/16ths.
