Craftsman 101 Lathe Question
  • Craftsman 101 Lathe Question
    Hello
    New guy here.
    Just bought a Craftsman 101.28940 Lathe.
    In the process of diss-assembly clean up & repaint. So far found & repaired several "cobbed" things & I like to know how things work prior to using the machine
    It has a quick change unit & I'd like to remove the head & QC from the bed for more cleaning, check out & paint
    Any reason I should not remove these from the bed
    anything I should look for while its apart
    And Any suggestions appreciated
    Thanks for your response
    Take pictures as you take the lathe apart so there's no guessing how things go back together. No problem stripping it down to it's smallest parts, you can check the condition of each piece as you clean it. If you mount an indicator on the tailstock base and indicate the ways you will get some idea of the wear, or not. Good luck on the rebuild. Peter
      Outside
      take the feed chart off there is a bolt underneath
      remove the two bolts on the lead screw bracket
      Any questions PM me
      George from Conyers Ga.
      Remember
      The early bird gets the worm, BUT it's the second mouse that gets the cheese.
        Get a copy of the parts manual or snatch a copy of the pages from the link below. It will help during re-assembly.
        http://www.searspartsdirect.com/part...0/0247/0728000
          Thank You Gents
          I'll try to post some pic when I complete the proj
