OT proper refrigerant disposal
  • OT proper refrigerant disposal
    I could not find an answer to this elswhere so pardon me for this boring question. I had a condensor unit installed outside the house and since the refrigerant used for the new unit was different than the old he flushed the lines... right onto my lawn ( actually It's a masterpiece of zoysia turf). Now I have to replace the soil as well as the fried turf in this small area in my otherwise flawless outdoor carpet. I wasn't there when he did it. I'm assuming that he contained the old gas and was just flushing the residue out of the lines.
    My question is: Is it proper (legal) to flush old refrigerant residue into the environment?
    Roland
    -Roland
    Golf Course Mechanic
    Bedminster NJ
    Nope. It's a violation of EPA regulations to purposely vent refrigerant into the atmosphere. It should have been pumped out of the system and recovered for recycling. But, are you sure he vented the refrigerant? He may have recovered the refrigerant like he was supposed to and then used nitrogen to blow the refrigeration lubricant out of the system onto your lawn.
      My bet is if he is other than a no name AC guy on the truck it is the oil that he flushed on the lawn.
      Glen
        Whether it was freon or oil does not matter. In either case its a violation of environmental laws. He should be busted and forced to pay for the clean-up.
          He recovered the freon but when he finished that he "flushed the lines". I don't know anything about HVAC but it seams to me it would be very costly to flush the lines with a closed loop system. So I'm guessing it's not proper to flush the lines into the environment but everybody does it?
          Thanks for the replies.
          -Roland
          Bedminster NJ
            Seems to me, EPA rule or no, he screwed your lawn up, and SOMEONE needs to pay for it, and it's not you.
              Its my understanding auto repair shops have cleaning devices for air conditioning systems and one for cooling systems. So the technology is available, he just didn't bother to use it (too cheap).
                Uh, Im pertty sure he did not dump a material that turns into a *gas* at room temp/pressure, onto your lawn.
                That is the part that must be recaptured, the gas.
                I have no idea if the oil is considered toxic or a hazard, but its not very nice to be pouring lubricating oils on the lawn.
                  Don't know how costly a commercial unit would be, but my brother and I rigged one up on the cheap one time. We had a big sintered bronze filter that was cleanable, we used an electric fuel pump and stoddard solvent to flush the system. Worked pretty good.
                  James
                    Yes, but I'm not going to get this Homer Simpson to repair my Michaelangelo.
                    Thanks for the info gents.
                    -Roland
                    Bedminster NJ
                      Most of today's flush agents are biodegradable (soap, and water soluble solvent) and the oil might have been mineral oil based. Still, that's no reason to dump it. The mineral oil is a hydrocarbon and remains so even in a soap dispersant. It should have been captured and treated as "used oil". If he did use a flush and didn't separate the compressor from the system and drain it, I can almost guarantee a future service call. The compressor retains a large quantity of oil that isn't flushed in the normal manner.
                      I still have some cans R-141b but it's used in a closed flushing system. It's the best flush/cleaning agent for ACs ever but no longer used since it's a HCFC. Nothing has come close to equaling it since it was restricted. I do occasional automotive systems in restorations and the first thing you learn is NOT to use stoddard-based solvents as a flush for new systems or conversions. If you do, you're not doing your customers any favors.
                        Forgot to mention-You can mix up a diluted liquid dish soap batch and spray it over the area. Follow that with a good watering (flood) to suspend the oil and let it run off to a less-sensitive area. Or pick it up if you have a pump. It will eventually degrade in a couple of months. What killed or burned the grass was probably the soap in the flush. I think it will recover on it's own if you keep it watered even if Zoysia doesn't like a lot of water.
