Engine dyno
  • Engine dyno
    I have been wondering how those old engine dyno's worked, the ones that used a strap wrapped around a flywheel, the end of the strap is attached to a spring scale, (or was it a stack of weights?)
    What I have always wondered is, how do they work in actual practise? I have visions of a lot of friction on that strap, friction=smoke, heat etc.
    Was weight applied until the rpm started to drop?
    Any ideas?
    Thanks, Peter
    See here-
    http://www.buckleyoldengineshow.org/...horsepower.htm
