new project- Enco 12x36- "taiwanese traytop" :)
  • new project- Enco 12x36- "taiwanese traytop" :)
    midway through my Sheldon rehab this popped up and i couldn`t resist- while it`s not "old American iron" ( or is it?? ) it`s hard to deny the practicality for a home shop.
    it will need a few little fixes but it`s actually in good shape and runs well- although until i get my garage wired up i can`t really run it for any extended period- the motor pulls 22 amps @ 115 volt! so it`s a given that i need the 220v for it.
    i`ve always been a bit curious about these machines and now i have the chance to check it out first hand!
    if anyone has any suggestions for improving(certainly lots of room in this area) i`m all ears!
    it should be interesting, anyway....
    Seems awhile back there were posts here concerning this lathe, and some "Positive" comments in favour of them.
      Hi 1200,
      From the look of it, it's much the same as the Jet 1224P / Warco BH600G - so, there's a really good mod you can do! The tumbler-reverse can be changed to a a single-tooth reversing clutch, which means no more worries about the thread indicator dial, no worries swapping between inch / metric / whatever thread pitches, adjustable threading stops for 300 RPM threading to a shoulder... It was mentioned in a thread on another forum [http://www.model-engineer.co.uk/foru....asp?th=49358] (a long thread, be warned!) and written up in (I think) Engineering In Miniature - the original was for the Myford, but has been developed for a range of different "hobby" lathes. It's not a *quick* mod, though!
      Another good mod is a 3-phase motor and VFD, drop me a PM with your email if you want to go that way, I have a wiring diagram from the conversion (I've done a few of 'em ) that retains the 3rd shaft forward / reverse control - it's also worth making up an improved belt tensioner, as the standard arrangement (at least, on the Jet and Warco machines) is pretty awkward to use...
      Other than those machine-specific mods, the standard QCTP and DRO?
      Just my ha'pennorth,
      Dave H.
      Rules are for the obedience of fools, and the guidance of wise men.
      Holbrook Model C Number 13 lathe, Testa 2U universal mill, bikes and tools
        thanks guys, i`ll get signed up and check out the site- so far this machine impresses me as far as it`s versatility- once i get a few things tightened up it should be a pretty decent machine.
        most notable is the bad fit of the cross slide and compound- very rough- there will be a little bit of work involved to get them working smoothly.
        funny you should mention the belt tensioner arrangement- that is why i got it cheap - the PO thought there was something wrong with it- turned out to be a too-tight motor belt in conjunction with a too-loose spindle belt - once i got the tension adjusted(yes,it`s a little wonky) it smoothed right out.
        the motor on this one is a Baldor, which i believe Enco offered as an option.
