Bilz tapping collets - how to?
That wasn't a whine, that was a bitch
Seriously I don't mind, I can't get them made and market them, chances are total sales over a year are sub 20 any way.
The Allendale / machine DRO lads are OK, we stand the same shows and get on well. When I wanted a new DRO for the Bridgy a while ago they really did me a good deal, they gave me trade without asking for it and even upgraded to a better display, again without asking.
John
I decided to follow up your idea about an MT holder, thought I would strike while the iron was hot (or at least while it was on my mind).
I'd forgotten until sorting through the Bilz collets that I had this holder, came as part of a job lot but it had a 32mm shank which was no bl**dy use to ordinary mortals:-
To make it more useful it needed a smaller shank, but first had to be dismantled so that I could hold it properly:-
It was a bit of a mess inside, with rusted springs etc. Cleaned it all up, found a couple of new springs which were somewhere near right. Then turned down the shank to MT2 taper, to fit in a sleeve:-
The shank was hard, but not too hard for a carbide insert. I couldn't go much smaller because of the internal bore. Then Loctited the shank into an MT2-3 sleeve.
Finally reassembly, that was a bit of a challenge. One unexpected issue was that it has six balls inside, three for the collet lock and three to take the drive torque. They all looked the same, but three were 4.95mm & the other three 5.15mm. It doesn't work if you put them in the wrong places!
Finished product:-
With all the messing about, took a good chunk of the afternoon which was not in the plan!
Tim
