Magnetic Scale DRO's and using other Magnets on Mill
  • Magnetic Scale DRO's and using other Magnets on Mill
    A stupid question from a complete beginner. That said, here it is. . .
    I am putting a magnetic scale style DRO on my milling machine. Will the magnetic scales or reading heads be damaged or generate measurement errors if I use strong magnets to attach items to the mill. Example, magnetic base that hold DTI's, or magnets to hold plastic chip guards covering ways of z-axis column and back of y-axis, etc?
    Thanks in advance.
    Take Care,
    Jim. . .
    It shouldn't have any effect, the inductive pick up on the scale usually has a two secondaries that are excited from a high frequency primary.
    http://www.meas-spec.com/downloads/P...f_the_LVDT.pdf
    The stationary field from a magnet does not normally affect them.
    Max.
      Max.
      Thanks Max.
      Take Care,
      Jim. . .
        Well, I think that depends a bit on the type of magnetic scale. If it's indeed using a transformer principle you're fine, however if you're using a magnetic tape I wouldn't touch the tape with the magnet. A magnetic chuck a few inches away I wouldn't be too worried about though.
        Igor
          Igor
          I bought the Electronica magnetic scale kit sold by DRO PRO in the U.S. I'm not sure how that kit factors into the type of scale you describe, but the magnets I use to on the mill are definitely within 2" - 3" from where the scales will be mounted.
          Take Care,
          Jim. . .
            The 'Magnetic Tape' or the Ferrand Inductosyn principle is also pretty immune to any outside interference.
            http://www.ruhle.com/rotary%20transducers.htm
            Shows rotary type, but linear is the same principle.
            Max.
