OT: Do Cyclotrons Only Consume Power
  • #31
    I used to help out my father there on his experiments on fusion. He was in the first program to figure out confinement which of course failed miserably. He was running an axial solenoid confinement machine and it all leaked out the ends. Then they tried end mirrors and it leaked out around the edges of the mirrors. Then they extended the mirrors along the axis and the plasma went snaky and contacted the chamber walls and on and on... The Bevatron had just gone into operation then and I watched one run where the beam was directed into free air on the opposite side from the control room. It made a flashbulb like bar of solid blue/purple ionized nitrogen about 20 feet long. The 88" machine was one of the first ones there if I recall correctly.
    • #32
      Originally posted by Evan View Post
      Natural gas is dirt cheap and will stay that way for quite a while now.
      Maybe not...... one big way it is cheap is "fracking", and that is getting somewhat close to being regulated out of existence in some places at least.....
      It's still "hot", because the hydrogen component obviously contributes only one of the more potent greenhouse gases around*, but NOT CO2..... so since NG has less CO2, even WITH the bad GG content, it's considered better, and is displacing coal..
      *Water vapor... sorta hard to get away from, but still a potent GG.
      1601 2137 5683 1002 1437
      • #33
        The new discoveries in Northeast BC ensure that gas will remain cheap in Canada for a long time. There is enough natural gas there to fill three 46" pipelines to the coast and still satisfy Canadian demand.
        • #34
          When I was a kid there was a science fair projects book in the library that showed how to make a linear accellerator. It looked like the one Evan posted. I can't seem to find the book online though.
          • #35
            It's the collected columns of C L Stong who wrote the Amateur Scientist column in Scientific American. I am pretty sure you won't be buying it although it is available.
            http://www.amazon.com/Scientific-Ame.../dp/0970347626
            • #36
              What makes me laugh when I think about it is that right in the middle of Berkeley, California, one of the only towns in North America to have a communist government
              Has never been true.
              and the centre of everything that is anti-everything,...
              Partially true
              there is, at the University a nuclear reactor in the basement of one of the halls. It's a small research reactor that can even run under remote control but is still a reactor. I wonder how many of the professional protesters know about it?
              Has not been true for 25 years. It was shut down in 1987 and everyone knew about it (which is one of the main reasons it was shut down.)
              -DU-
              • #37
                That seems to be one of those moronic Amazon prices for stuff that is no longer in print but, still around if you look enough. I have a hard copy of the CL Stong book that I got on one of the on-line book sellers for 30 or so bucks maybe three years ago.
                There was also the CD of the entire SA "Amateur Scientist" column in the above link that was available. I have an original of one of those as well that I bought when the Society for Amateur Scientists" first published it. There are downloadable copies of that floating around the web, and torrents of it as well, if one looks around enough.
                I wanted a particle accelerator too. Not sure why, but why not? I get to run one at work now form time to time, and I climb all over one almost daily.
                • #38
                  Other than city council financially supporting the local communist party and other similar activities, you are only partially correct. I was born in Berkeley and grew up there. Berkeley has a long history of socialism.
                  In the 1911 Berkeley elected a Socialist Party mayor, J. Stitt Wilson. A Socialist Party member was elected to the Berkeley City Council. About eight hundred people filled the Finnish Hall for a pre-election rally and later a victory celebration.
                  Wilson was a member of the Finnish Comrades' Association.
                  http://www.sjsu.edu/faculty/watkins/finntown.htm
                  • #39
                    I'm fairly certain that electing a member of a socialist party as Mayor in a democratic election does not change the political structure to being communist. If that were true our town would become a tribe if a Native American were elected Mayor. Berkeley politics do have a distinctly socialist lean, but that is within a normal city structure.
                    It seems there are a lot of reactors around. I can point out 2 "research reactors" within 15 miles of my house. Google maps give a good overview of one installation, but no street view. https://maps.google.com/?ll=37.60865...25663&t=h&z=16
                    Daniel
                    • #40
                      Read up on the history of Berkeley. You may change your mind.
                      Bad analogy. It isn't applicable to civic politics.
