'Barbeque' engine concept.
  • 'Barbeque' engine concept.
    I have an idea to build a 'model' engine to run on barbeque charcoal.
    Of course the ideal would be a gas producer and an internal combustion engine but I want to try something more 'primitive' than that. I want to try a charcoal burning 'atmospheric' engine, i.e. a charcoal burning 'flame licker'.
    From what I can determine a charcoal fire is much hotter than an alcohol flame and should(?) make for a more powerful engine.
    The engine would be a single cylinder engine with a water jacket for cooling, the intake path would be arranged to draw air through the hot charcoal bed and the exhaust would be through a seperate exhaust port.
    The engine would not be 'tiny' maybe a 4" bore and 6" stroke, depending on what cast iron drain pipes I can find. I expect there will be enough challenges to get it to run without trying for miniaturisation.
    Now for the questions and request for ideas!
    What can I line the furnace and intake tract with that will withstand the heat of the forced draft charcoal fire?
    Any ideas for intake valve material, which can take the heat? I am thinking of a slide valve with an easily replacable cast iron component.
    What is the end product of burning charcoal? Just ash and not tars that might gum up the works? I am prosposing to let the ash go right through the engine and out the exhaust but if it runs really well I would consider making a cyclone to go between the furnace and the engine. OK, the engine wont last forever with ash and grit going through it but maybe long enough.
    The engine will tend to run faster as increasing rpm draw more air through the furnace so I am thinking of mixing cold air into the intake tract as a means of speed control, any other suggestions?
    OK, daft idea that may never come to anything, but maybe.....
    I like this idea, although I would go for a hot air engine rather than a flame gulper
    But then, I can't get my flame gulper to work, my two hot air engines, even the one made of old cans, worked first time
    Richard
      Whats your definition for hot air engine?
        Something with a closed cycle, like a Stirling engine, a Robinson or a Ryder-Ericsson, or something like that
        Thinking a little more on this, a closed cycle engine would avoid drawing abrasive materials into the cylinder from the charcoal
        Richard
          OK Richard, I understand now. My friend Peter made a nice one of those with solid fuel...
            Your friend's engine looks pretty slick, a water-cooled Beta Stirling: http://en.wikipedia.org/wiki/File:Be..._animation.gif
            It looks like it might be big enough to do some actual work.
            Allan Ostling
            Phoenix, Arizona
              That is very cool!! I'd like to get some plans for one of those.
                Peter has made a number of engines all about the same size with various variations.
                Here is a short video of one in a boat..
                http://www.youtube.com/watch?v=ewKeNmXk59A
                Peter's home page is at http://peterlynnhimself.com/index.php
                  Among other design considerations, shouldn't the exhaust of a Barbeque engine smell delicious?
                    Olaf A. Berge (deceased) of Cass Lake, Minnesota, built full-sized engines from original patent drawings, he also displayed and ran these engines. Most were Stirling cycle of the older types. However he did build a "barbecue" engine from patent drawings that worked exactly as described in Artful Bodger's original post. I saw the engine at the Lakehead Harvest Reunion in Esko, MN, That was at least 20 years ago. Where it may be now, I don't know.
                    He told me that the flyash did cause valve problems, but I don't remember the valve type. Maybe someone who knows how could do a patent search.
                    JFLingg
                    JFLingg @ 25 miles east of Colorado Springs, Colorado
                      Thanks, that is very interesting so at lest there is no hidden law of physics or chemistry which would make my project impossible.
                      I am hoping that slide valves will be self cleaning, providing there is not 'sticky' gum or whatever in the hot gases coming out the bottom of the furnace.
                        Perhaps not impossible, but a "flame licker" engine doesn't have anything more than a partial vacuum to move the piston. [edit] This is different from a Stirling engine, which has positive pressure moving the piston on the power stroke.
                        Allan Ostling
                        Phoenix, Arizona
                          I really like this idea!
                            How about a Manson engine.
                            It's heat cycle like a Sterling engine, but the cycle is open.
                            Paul Compton
                            www.morini-mania.co.uk
                              Check these pages. The site and its companion http://www.notechmagazine.com/ are both quite interesting.
                              http://www.lowtechmagazine.com/2011/...-vehicles.html
                              http://www.lowtechmagazine.com/2010/...-gas-cars.html
                              bob
