Cleaning Aluminum
  • Cleaning Aluminum
    I am in the process of rebuilding a tri-band Yagi antenna for my Ham Radio setup. It was built wit zinc (or Cad?) plated hardware and over the years the plating disappeared and now the stamped aluminum boom-to-element plates are covered with rust stains. Other than using a stainless wire wheel or bead blasting any one have any good ideas on how to clean these parts up?? Tnx on advance
    Craig
    N1ABY
    Vinegar or CLR and Scotchbrite maybe?
      It depends how much effort you want to put in. If I were rebuilding it I would strip the aluminum parts down in a lye bath and then re-anodize them. Replace the hardware with stainless steel.
        You can buy aluminum "wheel brightener" at some parts stores. You are supposed to spray it on and then wash it off. I think it is a weak acid. It will also take off rust.
          Thanks to all. CLR and a "Welder's Toothbrush" cleaned them up almost good as new. Now all I have to do is put it all back together.....
          Craig
