If that is a "Flowjet" carb, the bottom needle is the high speed adjustment.
I have used those carbs,, all with a fuel shut off tap, BUT they will not run well or at all with a gravity fed inline fuel filter. There is just enough restriction in flow to kill them.
Even a large automotive inline filter wouldn't work.
Strange, as you would think enough fuel would seep through to keep it running.
Those are a very good reliable carb.
