Which bandsaw blade length?
  • Which bandsaw blade length?
    edit. . . . . . .
    Found the correct size on the site. Thanks for the help
    Well, 12" to the foot, so 5 feet is 60", leaving 4 1/2" so 5'4 1/2" is the blade you're looking for.
    I'm here hoping to advancify my smartitude.
      Which is 64-1/2"--same as the dimension used in the first post...
      Keith
      __________________________
        http://www1.mscdirect.com/cgi/NNSRIT...-SearchResults
        different model numbers but same specifications?
        And then there is a different one here http://www.amazon.com/5-4-1-14-18-0-...+5%274+14%2F18
        What is the difference between these? Theyre all the same size and specs of what I need but all three have different model numbers
