Can a hole saw do it? Is there another quick way to knock that big of a hole out? I'd rather not spend all afternoon at it with a boring head in the Bridgeport.
Thanks,
A good hole saw with lots of lube will be fine. Th trick with hole saw cutting alum. is to have enough drill press to keep the cutter going and to keep it clean--back out periodically so you can blow chips out. Should be no problem...
Keith
__________________________ Just one project too many--that's what finally got him...
A few more ways. Use chain drilling, vertical band saw, hacksaw or narrow reciprocating saw to remove the bulk and finish by boring on your mill. Naturally, if you use vertical band saw, you'll need to cut and re-weld the blade. Chain drilling followed by boring would be the easiest, IMO.
If you have a manual Bridgeport scribe the circle and cut a square out then nibble close to the line all the way round then mount your boring head for final cleanup.
BigJohn, my thoughts exactly.hole saws are ok , but 3/4in is a lot.If you can clamp it on the table, should not take long to remove the bulk and finish with the boring head. If the location is critical , you need to locate the center before you start. Bob.
Depending on size/shape, one could use a rotary table and an end mill.
+1 on the end mill/rotab method. 5 minute job, maybe?
I would definitely go with a hole saw, .125-.250" smaller than your target size. Chuck it up in the B'port, start the cut down maybe .05 dp, chuck up a .25 drill, and drill 4 or so relief holes along your saw line, through the plate. With a good stream of Al. cutting fluid, you will be flat out amazed how fast a hole saw will cut, with the relief holes giving the chips somewhere to go! Follow with your boring head, and you're done...
I would definitely do it with a hole saw. If 3/4 depth is too much, turn it over and finish from the other side. Keeping the kerf clear is important.
The typical hole saw uses a center drill as a guide, which works fine. If you don't want the center hole in the slug, you can remove the center drill. You will then definitely need to use a mill, as the saw will want to walk around until it gets a groove going. Without the center hole you won't have a reference if you decide to complete the hole from the other side.
The key to the whole operation is keeping the kerf and the cutters teeth clear- and use enough lube.
