A nice tool for touching up cutting tools
  • A nice tool for touching up cutting tools
    I picked up a Work Sharp knife and tool sharpener today. I had seen it work at a trade show and it puts a razor edge on knives that you can shave with. After putting a perfect edge on all of my crappy steel knives, I figured I'd give the slack belt configuration a try. There were some 5/8" HSS tool bits sitting on my lathe that had been ground to shape and used on a recent project. I was going to need them later tonight for another project and did not want to bring out the big bench grinder. The little 1/2" wide abrasive belts put an edge on that hss bit that you could cut yourself with. This little tool will work great because I have not sharpened my tools as often as you should because of the trouble of dragging out my sharpening set-up which I'm sure alot of people can agree with. It is light, quick and easy to get a perfect edge. I will say that is NOT for roughing bits to shape or heavy grinding, but it does what it is designed for very well and that is putting a very fine edge on things. The tool comes with 2x 80,220,6000 grit belts that have Norton printed on the back of them. I purchased the extra assortment of belts which also has 2 of each figuring that I would need them very quickly, but supprisingly the little belts held up extremely well.
    If anyone has any questions about this tool please feel free to ask.
    Chris
    Be sure and store your belts in the house where it is A/C. Other wise the splices will deteriorate, unless you use them up in 12 months or less.
    Ken
      Hello Chris, Had not seen this. Thank you for posting it. Regards, Earl
        Ken, I store my unused sanding belts in ziploc bags (with the air squeezed out) which seems to help them avoid coming apart at the splice.
        cheers,
        Michael
