OT: Windows & & AutoCAD 2000
  • OT: Windows & & AutoCAD 2000
    Has anyone out there tried loading AutoCAD 2000 on a computer using Windows 7 Professional?
    I'm hoping that one can. If not, would I have to set up a dual boot system with an older version of windows?
    No matter where you go, there you are!
    Hal C.
    I haven't loaded that specific combo but it shouldn't be any problem. Those older versions of Autocad are pretty platform compliant. Another program that you might try, and best of all free, is DraftSight. I haven't played with it a whole lot but it's pretty much an Autocad LT clone.
      Not sure if it relates directly to Acad 2000, but I was using Acad 2000LT, it was buggy and hung often on win7 64bit.
      I was able to run it OK using XP virtual mode, but that was a bit of hassle and eventually moved on to other software. Your mileage may vary...
        Acad 2000 would not load on my Vista laptop so I started using Draftsight. No complaints yet.
        North Central Arkansas
          Hi folks,
          I'm running Acad 2000 on my win7 64bit with no problems. I don't remember any problems with the install, so there is hope for you!
          ZL1OG:KH0EX
            AutoCAD 2000 on Win7 x64 here as well, no issues. There is a problem where it puts a lot of bank space in the "Programs and Features" menu (where you uninstall programs you no longer use), but that's regardless of which OS you run. It does not affect performance, and I've got a small registry patch that fixes it.
            Copy the text below to notepad, save as "all Files" with name autocadfix.reg. Doubleclick file, allow merge, fixed
            Windows Registry Editor Version 5.00
            [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\{5783F2D7-0101-0409-0000-0060B0CE6BBA}]
            "DisplayIcon"="C:\\Program Files\\AutoCAD 2002\\acad.exe,1"
              Thanks guys for the help.
              I'll be trying to do the install sometime this week. Hopefully it will go smoothly without too much hassle.
              Hal C.
                I have AutoCad 2002 and 2011 on my Windows 7 64 bit machine. I believe that 2002 is basically 2000 with a little paint on it. It runs OK on my machine, although it has been crashing on me lately. I much prefer 2002 over 2011. I mostly use Inventor, so on the occasions I need AutoCad, I go back to the version I'm use to instead of trying to learn 2011.
