Artist site, vintage tools
  • Artist site, vintage tools
    http://www.flamingsteel.com/my-vinta...collection.php
    stumbled across this artists site looking for vintage tools...posted partially because the tools are the style I like, and partially, I suspect, the feelings are similar to many who frequent this board.
    I know its appeal will not be to all but some of the simplest things...about 2/3 of the way down there is a pair of scissors and a hammer...can't help but think when you picked these up you knew you had quality in your hand.
    I don't think the site is overly commercial but please remove this post if it is out of bounds. Russ [no connection to site]
    Edit: oh, there are some neat tricks related to welding studio
    Cool site,thanks for posting.
    My favorites are the Lincoln welders and the pipe fitting bandsaw.
      Russ, thanks for posting this GREAT site, very enjoyable viewing!!
      Have that same old B&D 8in saw a beauty.
        Russ, I have a Lincoln 180 welder just like that, well I have 2 just like that. I have at least 20+ welders but last spring I needed to weld a crane into my truck & the only welder ext cord long enough fit only this old 180c I picked up. This thing weighs a ton but I managed to get it to the door, plugged it in & no fan came on, so I shut it off got my light & couldn't find a fan so I called Lincoln told them the model & serial # & asked if it had a fan. The guy said all welders have fans, put me on hold then came back & said this one didn't need a fan as it has a huge core. I hadn't welded in a year or better but I struck an arc the 1st try that used the entire rod, then another & several more. I weld DC but this 180 welds as good as any I've used. I pick these up when I find them. Thanks for the link!
          What do you mean "Vintage" looks like the photos were taken in my shop - I'm offended.
            I worked with that welder(same model) for several years during the 1960's in the shop of a tree farm(Evergreen Nursery,Inc). It did everything it was asked to do. ....just didn't ask too much.
            John M...your (un)usual basement dweller
              Russ, I have the brother of that book press, (except that it needs a paint job,) and I gave away a Beaver 15" band saw. My compressor looks to be a similar vintage, except that it is a Broomwade, while the motor, a repulsion/induction Leyland, MUST be from the 30s.
              A great site, lots of nicely restored tools.
              Duffy, Gatineau, Quebec
