Embarrassing question ... What the heck are these things called?
  • Embarrassing question ... What the heck are these things called?
    I'm having a total brain fart at the moment. There is an indicator that fits in the spindle of a vertical machine and aids in positioning the work piece. It has a dial and is meant to be used while the machine is running. Basically, you move the table left/right and back/forth until the needle stops moving. I've got an import version and, a few years ago, there was quite the controversy regarding the accuracy and usefulness of these tools.
    What the heck is the proper name for it?
    Coaxial indicator?
    Chuck
      as Chuck says. Blake is the bid name brand. Got one recently....probably the single biggest example of "why the heck didn't I buy one 20 years ago" I've had
      They wouldn't be as accurate as a 10ths indicator mounted on a rod, but they are pretty darn good and soooo easy to use and quick centre the spindle. As always, its not a Q of right and wrong, it's picking the right tool for the job, taking into acount the pros and cons of each and whats required
        Thanks guys! I've got one and I love it but I wanted to pick one up for my BIL for Christmas. I'm at work so I couldn't even look at mine to remind myself.
          I wouldn't be without my Blake. Just WAY too handy for quickly centering up holes,punch marks,sides of cylinders,etc..
            I don't have a coaxial indicator but I do have a 3D taster that I wouldn't part with for anything. For centering the spindle on a hole or a cylinder or finding the edge it is fast. Now a punch mark I don't think it would work.
              Guy Lautard's site is offering ready-made rockers for the coaxial indicator project from his #3 bedside reader.
              http://lautard.com/rockerpage.html
              JCHannum built one:
              There is a long (winded) discussion of the coaxial indicator here http://bbs.homeshopmachinist.net/thr...xial-Indicator and includes far more than anyone likely has a need to know. For some reason this is a controversial instrument. It might be less stressful to argue politics or health care
              I bought an Asian knockoff of the Blake for about $75 and it is worth every penny which is to say not much. It works but has about 1؛ of internal error (the dial, while not calibrated in degrees, is measuring the offset angle of the rocker).
                Hah! That was the thread I was thinking of when I referenced the "controversial topic" in my OP. Glad you dug it up.
                My import one was quite a bit more than $75 but I've been very pleased. To me, it's like having a 3 jaw chuck on the lathe. You lose a little accuracy but it's super fast. If I really need the accuracy, I've got an Interapid DTI that I use - but for most of what I do, these little knick-knacks are great!
                  Trying to remember - I think they were commonly known as "SPINNERS".
                    We had a Blake in our toolroom but the primadonnas were pretty much the only ones that used it. I never tried it, just relied on my trusty Starrett Last Word like I had for years.
                    Now that I have been doing some commercial work and there is more often pressure for delivery, I decided to get the Blake. I have not used it much yet because I haven't been taking on a lot of work since I got the Blake but I can see that it will save maybe a minute every time I need to indicate a hole and more importantly it saves me from having to bent my neck around to see a last word.
                    The Blake was an auction find and I spent around $165 for an indicator lot but it included about 15 other indicators from a couple of Swiss made ones in .001 and .0001, a federal or 2, A couple of starrett sets and more. A real score. I thought the Blake needed service because it felt somewhat sticky but when it turns it is free and works like it should. Score one for the good guys.
                      Remind me again why it's not faster to just put a center finder (conical tip) in the spindle and jam it right into the hole?
                        The coax is the same speed as the wiggler (and some argue that it is more accurate than a wiggler) but the real advantage isn't for small holes but for large ones. In my rotary head mill, I often find myself setting up to enlarge a circle or center a part with a large bearing pocket, etc. An edge finder doesn't work in those situations. Similarly, I use my coax for centering a cylinder in my mill, since it can trace the outside diameter of a part as well as the inside.
                          I have a co-axial and a 3D taster and for most jobs I go with the taster and like Black Forest I wouldn't part with, ever.
                          Southwestern Ontario. Canada
                            Depends on the size of the center finder and the size of the hole.
                            http://www.youtube.com/watch?v=ZfioLDhBNBQ
                              The Starrett Last Word indicator is cute,and I have a few, BUT,it is not sensitive enough for high precision work. Takes too much force to move the tip. If you were using it to center holes,you were not getting as accurate results as the Blake would give.
