Model Steam-engine goes ... BOOM!!!
  • Model Steam-engine goes ... BOOM!!!
    Looks like people 100 years ago were smarter than these fellas. Pressure release valve anyone?
    Steam Engine explodes
    Oh dear. That was bad.
      Strange place to be running it, looks like he had it on the living room floor!!
        And it didnt blow out the flame on the torch, nor do we see any of whats left... Hmmm...
          No Safety valve obviously
          Steam expands 1700 to 1.
          Gunpowder is like 300 to 1
          Rich
          Green Bay, WI
            Another one with a slippery hold on his perch.
            Michael
              That's what happens when you overheat the vessel,it ruptures BEFORE the relief valve pops off.
                Mr. Darwin, looks like you have your next prize recipient here...
                  Just hope he doesn't take out anyone else, except of course ones just like him.
                    Holy fudge!
                    They would be lucky if poopy pants were the only casualty from that explosion! Yikes!
                    Jon
                      could have been no safety release valve, old boiler with zinc depleted brass bushings clueless made up design that wasn't strong enough or even the use of soft solder. The great majority of people haven't a clue why a boiler is so dangerous....even on technical forums, most things its comparable to say compressed air (not). Hopefully no one's kid gets wiped out
                        Without so much as a twitch of the crank!
                          This clip is getting long in the tooth and keeps being repeated to show members of the damp gene pool. If you listen to them, the safety (or relief) valve has been tightened, reffered to as the "Valve of death", so they were quite aware that they had pratted about with the weak link.
                          Dumb and dumber then publish on "Tube"??????
                          Regards Ian.
                          You might not like what I say,but that doesn't mean I'm wrong.
                            They have the torch pointing directly on the joint of the steam tube at the bottom of the boiler, the solder whether soft, hard etc let go.
                            Glen
                              the piston is fully extended ..and the engine will not self start without a push on the flywheel.
                              the tank is soldered ..he melted the solder with his blow torch .
                              all the best.markj
