Grizzly G4003g Gear Help Needed
  • Grizzly G4003g Gear Help Needed
    Do you own a Grizzly G4003g? If so, I your help.
    I have an older (1985) Morgon 12x36 belt drive lathe that has a couple of holes in its threading range that I would like to fill. To do this I need 35 and 60 tooth gears and I think the gears from the 4003g will work, but I would like to be sure before placing the order.
    My lathe uses Module 1.25 gears with an 18mm bore and a 5mm keyway. The gears are 10mm thick with a 10mm boss. The OD should be 46.25 for the 35 tooth gear and 77.5mm for the 60 tooth gear.
    If you could do a quick measurement and confirm that the 4003g gears will (or won't) work, I would appreciate it.
    Glenn
    60 tooth Approximately
    Hole (bore) 19mm
    Keyway 5mm
    Thickness 10mm
    Diameter 92.81mm
    Boss 12mm
    35 tooth
    Hole (bore) 16mm
    Keyway 5mm
    Thickness 10mm
    Diameter 55.25mm
      Thanks Ron -
      Looks like I'll have to continue my search as these calc out as Module 1.5 and the bore is too large on one.
      Thanks again.
      Glenn
