9X20 drive belt.
  • 9X20 drive belt.
    Where is the best source for the skinny belt used on these lathes? I have found several places on the web, but $30 seems a lot for this belt. I can buy a REAL V belt from my local hardware store for about $6 or $7. Mine is about 15 yrs old, and has cracks, but still works. I realize that the strength is on the top of the V much like a serpentine belt on a car, but I would like to lay In a spare or two anyway. Bob.
    That takes a Gates 5m710 polyflex belt.Any good industrial belt supplier will have them.This is one-
    http://www.royalsupply.com/store/pc/...710-p40301.htm
    There are several others,Applied Industrial Technologies is one-
    http://www.applied.com/apps/commerce...g.do?e=2&c=585
    Motion Industries is another-
    http://www.motionindustries.com/moti...0%26%20Sheaves
    Forgot to add,check the length of your existing belt as it's possible they may have changed the design of the lathe over the years.
      I found that different years used different lengths. When I bought mine it had a belt so tight that changing to the other pulley was a chore. If I recall correctly, the 710 is 710 millimeters. The replacement was 720 and works fine on all settings.
      Dan
        Vbelts4less.com
        Pair of 710mm metrics plus ups-----36 bucks
        Guido
          I am feeling generous - will start a new thread.
