Hey Flylo.... you're missing out.
  • Hey Flylo.... you're missing out.
    You could own this...
    http://seattle.craigslist.org/see/tls/3425902336.html
    Probably works fine; just not very useful today. I do see 3 nice heads, 3 very nice vices, great welding fixture (table is about 6 feet long), a bunch of hydraulic junk and a 3-4000lb of scrap iron (5c lb right now). Tempted myself.
    Wish it were closer! Thanks!
    country, in easy stages."
    ~ James Madison
      Perhaps for Sir John instead, so he could have 3 times the POS bridgeport?
      J
        That's an absolute steal.
        I'd love a step speed head for my machine to replace the 2J varispeed. If cheap inverters had been available years ago the varispeed head wouldn't have needed to be invented.
        Get a step speed head, throw the motor away, stick a 3hp motor on and 2 or 3 speed poly vee drive and invertor and it would transform one out of this world.
          The vises alone are probably worth $1200.
            Seen a lot of BRPTs but never those motors, looks like they cobbled up some thing to keep them running.
              I have run 2 and 3 headed Bridgeports just like that one. They take a lot of setup and fine tuning. Also you have to make the first part to copy some other way, and a stylus to match every endmill. Once everything is set up and dialed in they work pretty good. I was able to keep all three parts within + or - .002 running production. We didn't have Kurt vises back then, mostly used shop made mill fixtures. Having run those, I appreciate my CNC mills a lot more.
                That machine has to be his worst nightmare
                  I've seen many tracers around here with atypical motors - they were usually equiped with 5hp GE motors instead of the wimpy 1hp. Torque without needing backgear!
                    LOL
                    Last place I worked at we had two bridgies that stood in the middle of the shop, back to back.
                    Often used to swing the head round on one so it was over the bed on the other to give two heads for drilling crude spacing jigs for the converyor systems on the spray line.
                      "True-Trace 3D Hydraulic Tracer" We don need no steenking G-code!
                        personally I'll take G & M code over a tracer any day.
                        As others have said buy it for the vises, strip off the heads and sell them, sell the hydraulic power pack or use it for a log splitter. Use the table as a welding table and scrap the remainder. Probably make a good profit out of it.
                          I saw that listing within a minute of it appearing, and it's only 45 minutes from me. You can't image how many time I've nearly pressed the reply button, but I'm exercising self control. Much as I would like a couple of spare heads.. and vices.. and...
                          STOP! Turn off the darn computer.
                            Me too. It was an attempt at humor.
                              Get it! You know you want too. Go ahead make the call & offer $600.
                              ~ James Madison
