How about an O/T riddle?
  • How about an O/T riddle?
    Found this on another site:
    There is a fitting/part that was invented back at the turn of the century that was used on Model "T''s, and has been used on every vehicle built since then, no matter the make.
    Any guess's what it is?
    A pic would help.
      Wouldn't that be the steering wheel? They used tillers before that.
        How old are you when your are 1/2 your parents age?
        Stevet
          A singular loose nut. Located directly behind the steering wheel.
          Gene
            Stevet - The age they were when you were born.
              You really need to find another job to keep you occupied...it's a Schrader Valve...the little thang in the valve stem! It would be neat if you thought this up yourself but it's real lame to go behind enemy lines and infringe copyrights.
              Stuart
                Come on guys, each of you has this part on your vechiles .
                  REALLY??
                  I POSTED that i had found it mentioned on another site. Not GOOD enough?
                    I read it on the other site as well! lol
                    But I think "the nut behind the wheel" is a better answer.
                      Must be the FULL moon.
                        electric starter?
                        Oregon Coast
                          Originally posted by lugnut View Post
                          electric starter?
                          In a model T? lol
                            Radiator Petcock?
                            NRA Life Member
                              From the hint, I'd say gas gauge.
