New( to me) Truck!
  • New( to me) Truck!
    I'm a real fan of 2nd Generation Cummins/Dodge trucks which were only made from 1994-19981/2. These are mechanicly controlled engines just like Case/IH put in their farm tractors. I have a Heavy 3/4Ton 1995 4x4 & love it for the power & fuel economy. I ran across this '98 1 ton with a 12' flatbed 1/2 mile from bborr01s place. It has 110,000 miles & drives,runs & operates like new. Not bad for a 14 year old truck! Hope my wife likes her present. LOL
    country, in easy stages."
    ~ James Madison
    Nice truck flylo but that deck is just begging for a load of iron.
    I know...it won't be long. LOL
      That's anice loking truck car at the front,and a truck at the back,nice looking all round I wish you well with it for the next fourteen years> Alistair
        Just got a '97 myself. 188,000 miles, runs great. (you do know about the Killer Dowell Pin, yes?)
          Nice truck Flylo!!
            Very nice, is it the 12 valve or the 24?
            Just rock solid engines...
              Dfw, Nice truck also! Yes I'll have to do the dowel pin. I was afraid it has a brazilian 53 block but I had it checked before I bought it. The 2nd gens are so popular & getting hard to find, so I had to snatch it, with 110K it's just getting broken in.
              ~ James Madison
                Last of the 12 Valve.
                ~ James Madison
                  Nice truck Eric. I didn't see it for sale or recognize it from my hood. Now if I need to flatbed something, I knot who to call.
                    Hi Brian! It was across from the airport, next to the tranny shop just south of you on the same side. I don't think he had it long.
                    ~ James Madison
                      I have a 12V. Can't beat it with a stick. Good fuel economy. Starts every time. It's the 5 speed manual, rear wheel drive, so the econo-special. It's not a hot rod, but it will pull anything you hitch it to. Plus, it seems to tolerate my first class biodiesel that I make.
                      Glad you got a nice runner. If you really got it for your wife, tell her it's better than the bowling ball you were thinking about.
                      Finest regards,
                      doug
                        Now you guys have done it,shortly there will be somebody along who will insist all you really need is a Honda Civic or a SmartCar
                          Dowell?
                          OK: What's this about the "Dowell Pin"? Where do I look? And why? Wayne.
                            The 12 valve Cummins engines have a dowel pin in the timing gear case with a history of sometimes dropping out into the gear case. Sometimes if you are really lucky it will just fall to the bottom of the timing housing and into the oil pan and cause no further harm.
                            But with all of those gears in that housing more often than not it will lodge between a set of gears with disastrous results.
                            The fix is an easy one once the front cover is removed from the gear case housing.
                            Goggle "killer dowel pin" and you'll receive all the info you need. Below is but one example.
                            http://dodgeram.org/tech/dsl/Dowel_Pin/tab.htm
                              Lot's of info @ Geno's http://www.genosgarage.com/
                              ~ James Madison
