Cutting a 1/2" 10 left acme thread
  • Cutting a 1/2" 10 left acme thread
    So I am trying to make a new cross feed nut for an atlas shaper, not having a very good time. After all the work making the blank and then centering started to cut and something's gone wrong may have engaged at the wrong time or there's too much flex in the tool, anyway thread looks awfull and I can't seen to test the leads crew to it as it won't start. Anyone had luck single pointing something like this. Taps a 100 plus shipping, might try and make my own did it once befor. http://pbckt.com/pL.QFkrr6. http://pbckt.com/pL.QFkDdS.
    What I making and what I've made. Anyone in Edmonton with a tap?
    The cutting tool needs to have the flanks ground for clearance, which means taking into account the helix angle of the threads. Brass can be a chore to cut internal threads in. Tool needs to be sharp. Also, it's pretty easy to have the bottom of the tool rubbing- again, this is a clearance issue. Sometimes you can help this situation out by raising the tool a bit above the spindle axis.
      Of what I see looks like you are getting there. A nice sharp properly ground
      tool is key. However any internal under an inch is tough as far a flexing.
      I think the only way is many many light cuts. My old eyes, what I can see
      looks like you need more root. Fiddle with tool height like Darryl said. Im also
      thinking even if you go a tinch more I dont think it matters its not that too
      critical on a shaper like as half nuts on a lathe. Ps Myself I would make a
      second one.
        I usually just make an acme internal threading bar out of an Allen (hex) wrench of the largest size that will fit (you know cut off the excess L part and grind the cutter shape close as possible to the main, longer bar). Follow the tips already given by darryl, and big job, then do many, many passes, often at the same depth of cut until actually clean threads all the way through the depth of the part, then move on to a deeper cut --lather, rinse, repeat. Eventually it gets done... eventually. Don't hurry it, won't work.
          I had to replace the Acme threaded rod and nut on my older lathe a few months ago. Since the lathe was broken there was no possibility of making one so I went to McMaster Carr for the rod and nut. They have precision left hand Acme rods and nuts, but be sure you're sitting down when you look at the prices for the nuts.
          The price of the precision left hand threaded rod isn't bad. A 3' section is $34.40.
          http://www.mcmaster.com/#left-hand-t...e-rods/=koaxzn
          The precision platform nut however is a bit pricey at $118.43.
          http://www.mcmaster.com/#precision-a...d-nuts/=koaumh
          Hopefully you don't need that fancy a nut for your application. Mine had to be machined and fitted into the compound. It ended up about 1/2 its original size. All is well now with the repairs. It's as accurate as the day it was new.
          I'm willing to bet that if the nut is worn to the point it needs replacing the rod also has a fair amount of wear.
            You can also gash the end of an old acme rod and use that as a "clean up" tap in brass.
              I'm not sure if acetal's up to it, but you might want to try this: http://bbs.homeshopmachinist.net/thr...s-the-easy-way
              J
              PS: I'm in Edmonton, don't have the tap, but wouldn't mind meeting other metal munching minds.
                Single-pointing the internal thread is difficult because there's a lot more deflection force cutting an Acme. I suggest you follow the other's tip about using a piece of the leadscrew to make a tap, but first single-point it most of the way first. That will keep the thread concentric to the bore and will make tapping much easier.
                  Just yesterday made eight pieces that had a nice trapezoidal thread - 12.71 mm pitch, 40 mm length. Best result was obtained by first opening up the thread with a grooving tool and only after that I used my form tool.
                  Here is a nice trick:
                  Use a form tool that is narrower than the final thread. Take a touch from the bore of the thread and move the cutter to the final diameter, but put a suitable bolt and extension nut between the lathe cross slide and the cross slide dial (or similar place), so that it stays firmly in place when you wind the cross slide to the required diameter.
                  Start cutting as normal, but advance the tool with the top slide (that is parallel to the ways) and thus work open the sides of the thread.
                  This is way faster than cranking to such-and-such diameter over and over and also easier on the tool as it can be narrower than the final width. The only downside is that this requires opening up the thread first with a grooving tool to the final diameter.
                    Jaakko
                    Good point !
                    I have used square tools to rough the Acme thread to reduce the cutting load, but having a narrow tool with the 14 degree angle makes good sense
                    12Teeth
                    100 years ago I lived in Canada and also had to make a 1/2-10 LH Acme nut , for my lathe crossfeed.
                    I did the best I could with a form tool, being careful to not go oversize, and then I took the leadscrew off the lathe and ground cutting flutes in the first 3-4 threads, then used the leadscrew itself as a tap. Usually the end is big as it gets no wear.
                    Took a bit of in/out, but I was able to tap with the screw and got a beautiful sliding fit in the middle of the screw when assembled
                    Basically the leadscrew was a finish tap for the job
                    Rich
                    Thanks
                    Rich
                    Green Bay, WI
                      I made a cross feed screw and nut for my Atlas shaper 6 years ago. The screw is 1144 stressproof, and the nut is just a brass cylinder, like the original. The screw was threaded between centers, with a follow rest. No way you'll get a consistent thread depth without one. 1144 cuts beautifully, and doesn't warp. The nut was also threaded in the lathe, in the four jaw.
                        J
                        Can anyone post a reason why an acetal nut, formed using Evan's method wouldn't be able to handle the stresses of being used on a small shaper? I'd buy a new length of left hand Acme rod and form the nut as described in the above thread. Maybe form several nuts. Even if they only lasted a year between failure, you could simply replace them.
                          your exactly thinking my way rosco. its not for making rockets or anything else thats requiring high scruinty. . . whatever works and is easy.. .. .. even should chime in here. . .
                          oh hell, what do i know ? ? ? ? ?
                            In this application (the cross feed) the stresses are low, so the acetal should be fine.
                              I've got some hard mystery plastic, mayby I will make one from that. I would like to have one more try at the brass one though, my tool was a little spindly as it was made for a 3/8 acme screw for a myford. Didn't have much luck that time either so I made the tap which worked fine. Thanks for the suggestions.
                              Darrell
