Pressure Gauge On Shop press
  • uute
    That's one way to increase the capacity of your arbor press!!
    I also like the carrying capacity (though I'm not sure the casters are up to it) and fact that pressure chart is hidden behind I beam. LOL
  • oldtiffie
    http://i200.photobucket.com/albums/a...ydraulics1.jpg
    http://i200.photobucket.com/albums/a...spressure2.jpg
    http://i200.photobucket.com/albums/a...ydraulics2.jpg
    http://i200.photobucket.com/albums/a...ydraulics4.jpg
    http://i200.photobucket.com/albums/a...spressure1.jpg
  • atomarc
    Although not a technical answer, my air over hydraulic pump and hydraulic press cylinder is equipped with a pressure gauge. When pressing, I check the gauge...when it gets too high I close my eyes, pucker my tailpipe and pray to higher powers...that's what I use the gauge for...
    Stuart
  • Toolguy
    Mine is attached to the top of the cylinder, so reads pressure directly off the hydraulic fluid. I find it useful for bending and straightening. If you know what pressure you were at and need just a little more or want to go back the other way the same amount it will get you closer than a wild guess. With hydraulics there is no feel like on an arbor press so the only way you can tell what it's doing is a gauge.
  • Rich Carlstedt
    Commercial ones show tonnage of force.
    This of course is a predetermined multiple of the hydralic pressure and the area of the piston
    Rich
  • spinrow
    started a topic Pressure Gauge On Shop press
    I recently got interested in getting a shop press. I see some presses come with a pressure gauge and wondered why is a gauge necessary and how is it used? Thanks Paul
