Hey all you sketch-up artists out there...
  • Hey all you sketch-up artists out there...
    Hey guys,
    Once more I am trying to wrap my head around 3D modeling. I have been drawing with autocad (2D) and draftsight for several years now. I have tried several different 3D drawing packages (turbocad ect.) and been completely frustrated with them. I am now going to try Sketch-up 8. I am working in a Mac enviroment if that makes any difference.
    What I have so far is a 6" tall cylinder with a 2.5" diameter. I have a stepped hole bored down through the middle of the cylinder along the long axis.
    What I am trying to do now is apply a .125" champher to the top and bottom faces.
    Can anybody tell me how this is done?
    Thanks,
    Tim
    This might help:
    http://sketchupdate.blogspot.com/201...ndcorners.html
      not sure whats all on sketchup , but making 2 torus , 1 bigger , then subtracting one from the other leaveing a reverse champfer , then copy it and put it on the end and subtract it from the main part (ive only used bobcad , heeks , dolphin , so im not sure if you can do that )
        On mine I select the edges I want champhered, click the drop down tool bar for champher, and specify the size and angle of the champher I want.
        Then once again in the actual tool path I select a champher tool of a given angel and specify the cutting depth of the tool and the program will calculate the distance of the tool center from the edge
        Of course this is a 3 axis mill rather then a lathe
          Joe, are you using the free version of sketch-up 8 or the Pro version? I am using the free version and I don't find a champher tool under any of the drop down boxes or tool bars. is it maybe a plug-in?
          Tim
            Simplest method:-
            1: Offset Tool : offset (copy) the corner edge 0.125" 'inwards' (creating a new circle on the cylinder end surface)
            2: Move Tool: drag the corner edge down 0.125" (the chamfer is created between the two circles)
            Cheers
              Thank you Barrington,
              That worked very well.
              And thanks to all who responded
              Tim
                Originally posted by Barrington View Post
                Simplest method:-
                Cheers
                That animation is neat. Could you share how you created it? Was it done with Sketch-Up?
                Make it fit.
                  I used the free version of 'Screencast-O-Matic' , saving the recording as an animated GIF. (That was a bit large for a forum post (~3Mb), so I reduced the quality in Jasc Animation Shop which got it down to <300kb.)
                  The prog is quite basic, but in a good way - simple to use and not too many options to worry about.
                  Start the prog, adjust the capture window size, (& select a mic or a webcam insert if required), start recording.......stop recording, and save in a variety of formats, + automatic upload to a YouTube account if available.
                  (The downloaded prog is here , not the on-line version which needs an evil Java plug-in .)
                  Cheers
