Turning titanium?
  • Turning titanium?
    I need to make a couple of small parts from 3/16" titanium rod. I've found some 6AL-4V in an appropriate size, and I was wondering how my Geometric die head might handle the threading duties.
    It doesn't seem to have any real trouble with stainless rod of the same size, though I can't recall if I was using 303 or 304.
    I don't, however, want to ruin a good set of dies, or worse, damage a $200 die head in trying. Has anyone tried this? What's an appropriate lube?
    Doc.
    I have single pointed titanium and it is not bad. Just watch your SFM otherwise you will kill your dies right now. Personally, if it is just a couple parts I would just single point them.
    I have used high sulfur cutting oil with good results.
    Titanium is no big deal to machine. Just dont stop cutting and let it rub.
      Doc I threaded some 5/16 female holes out of the same 6al4v. I even bought the titanium tap and the fancy pink goo for threading titanium. And got the tap stuck on the first hole, locked up tight. I ended up single point threading with a carbide threading bar. All I can say is good luck and keep the part flooded with coolant. 6al4v is one of the hardest common titanium’s out there.
        That alloy is tough, and it'll work harden if you look at it cross-eyed.
        For external threading, I would not use a Geometric die head unless you bought new chasers that are ground specifically for that material. They would need increased hook and back relief grind. Better to single point it, though I'd be using carbide insert threading so I can stay heavy on the depth per pass. If you are using HSS, keep the cutting speed down to about 15-25 sfm, and don't take less than .002" depth per pass.
          i have done a lot of with with titanium and have never encountered a special tap for it. I have had no problems with normal high speed taps. What was different about the tap?
            Use coolant. Cutting titanium generates an astounding amount of heat. And you don't want it to catch fire. Wicked sharp HSS will work about as well as anything, I think.
              Agreed, standard safty warnings, titanium is somewhere inbetween aluminum and magnesium as far as fire hazards go. Kinda hard to ignite but be afraid if it does! Consider getting the chips outta the house ASAP if they are going to end up mixed with other metals/oils/etc.
                I ran many feet of titanium through multi spindle screw machines in my youth, and sawed, milled and turned it later. If you can work with stainless steel you can work with titanium, the issues are mostly the same. In the screw machine shop we had one fire, caused by a broken drill.
                  OSG 312 series http://www1.mscdirect.com/cgi/NNPDFF...4213&PMCTLG=00
