What did I buy?
  • What did I buy?
    Was pawing through the used tool section of a local shop and found a little box of hand-ground HSS boring bars. Randomly mixed in was this item:
    Given the dark-gray appearance, heavy weight, and mirror-finish polished pointy end, I thought it might be a solid carbide dead center. It was individually marked $1 so I shrugged and bought it. When I got it home, I found it mildly magnetic, and the point was able to scratch steel very easily.
    I know the above picture is the worst one in the world, but... what do you think? Dead center, or something else? If it is a dead center, can I just chuck it in my tailstock Jacobs chuck?
    Hard to say because I can't see the end too clearly, but it closely resembles a diamond dresser for grinding wheels. Is there a dark thing brazed onto the end?
      Part of a broken carbide end mill.?
        Dead Center?
          Punch for an optical center punch?
            There is a second, more obtuse angle near the tip, but it's all one solid piece.
            Come to think of it, the included angle is 90°, not 60°, so maybe it's not a dead center after all?
              It's a left hand version of one of these.
                Tips for hardness tester?
                Probably carbide as it is also mildly magnetic.
                Either way dont use them as center punch.
                They will shatter in your hand.
                FSWizard - Free Online Speed and Feed Calculator
                  Must be my lucky day ------- SJ - forget the tool fool, i'll give you five pounds for that quarter you have...
                  can come up with the goods tomorrow morning (after I have my coffee)...
                    It's an optical emission spectrometer electrode, should be 1/4" dia with a 90 degree inc point made of 99.99% Tungsten, looks like to me anyway!, mainly as I have a box of them that are too short to be used any more, it should feel quite weighty in your hand.
                    Mark
                      I know what it isn't, a hardness testing indented. It does , however look like an punch from an optical center punch.Bob.
                        It is quite hefty for something so small.
                        So, I got to thinking. Since the extreme tip has a slightly larger angle, the tip will not bottom out in a 90° hole. And, I also happen to already have a 90° spotting drill I can use to centerdrill stock. So even if this thing is properly a widget for some other application, I think I can still pervert it into use as a dead center.
                        It's too short to bottom out in my Jacobs chuck, though. I might need to drop a spacer into the bottom of my chuck to use it, as the steel chuck jaws probably won't be able to keep the carbide from slipping back under tool pressure.
                          I ve heard somwhere regular jacobs chucks run out too much.
                          If you had one of them hi precission chuchs then that might habe veen a different story
                            A former co-worker was using an old socket handle, ground to a point, as a punch.
                            It shattered when he hit it, and he had to have surgery to remove the shrapnel from his hand.
                              Looks like a piece of micro-grain carbide to me.
