Cutting Bolts in the lathe.
  • Cutting Bolts in the lathe.
    How do you hold bolts and screws to modify or part to length in the lathe?
    For most small ones I generally cut them with an abrasive disc on the dremel and finish on the belt sander.
    For larger bolts I generally hold them in a coupling nut or similar and machine on the back side to tighten the threads. Cutting off to length gets to be a little more difficult so I was curious how others do it?
    Would a split nut held in the chuck have enough grip to hold the part from turning if parted from the front?
    Byron Boucher
    Burnet, TX
    Split nut is one option, though for modifications I use a cutoff machine. It has a small V-jaw that has holds the bolts/pins/etc. while cutting. Another option is a block with different thicknesses and threaded holes tapped in to the steps, just run your bolt in and cutoff from the other side of the step.
      Hacksaw. No, really. If I had to do a lot, I'd find a better way.
        The only use for a 3 jaw chuck: holding hex heads on bolts securly.
          My favorite way is to use a 5C collet and a hexagonal collet block in a 3 or 6 jaw.
          I have also used a coupling with a jam nut.
          (Sometimes I use a hacksaw in a vise. I always try to put a nut at the top of the bolt I am cutting so when I remove the nut it chases the threads I have just boggered up. With a hacksaw, always move your thumb before you lean into it, because it sometimes wants to jump around)
            Lantern chuck.
            Paul Compton
            www.morini-mania.co.uk
              I don't part off much, unless it's aluminum. The most popular hand tool in my shop is a port-a-band saw. I cut to rough length, then finish off the end in the lathe, 3 jaws are great for this.
                Bench vise and hacksaw.
                  I use a hacksaw with a vise or lathe chuck holding the bolt. Then finish the end on the lathe, using a specially made split nut.
                    Get a bit of 3" or 4" square hollow ection (SHS) say 8">10" long. Square the ends up on your band-saw (if necessary).
                    Get (say) 2 bits of 1/2" or 3/8" plate cut to suit the ends of the SHS.
                    Drill and tap as many of your commonly used threads into the end-pieces.
                    Weld the end pieces to each end of the SHS.
                    Job done.
                    To cut any screwed section, spin on a bolt to sit the bolt etc. to be cut and spin the bolt etc. into therequired thread/s in the end piece/s.
                    Clamp the SHS in the vise on your band saw.
                    Adjust the bolt length to suit using you band-saw blade as a zero/gauge.
                    Tighten the (lock) nut and re-check.
                    Cut the bolt/s.
                    Job done.
                    Use any effective variations to suit your circumstances.
                    Start the band saw.
                    Job done.
                    Weld (say) a 1/2" or 3/8" pla
                      What? You mean the fact that I've been using them for over 35 year to hold and turn round stock into good parts is all wrong?
                      Why is this? Is the something about parting off steels or other materials that is problematic on a lathe? This is an area that I just can't understand the mystery of doing it. Get the right tools and it's easy as pie. Use the least optimal tools (old HSS blades on a lantern tool post) and it can be tricky to dangerous.
                        Cutting bolts to length is something I do fairly often. Done on the bandsaw, a piece of scrap is drilled and tapped, then the bolt screwed in. Depending on the length needed, there's either a spacer on the bolt, or the scrap is the right thickness. In some cases I drill a hole through a block of scrap, then insert the bolt to be cut- sometimes there's a kerf cut into the block at the right distance from the bolt head. In these cases, the bolt is loose, so I prevent it from turning using a wrench, sometimes vise grips, sometimes a socket. This is probably the method I use most, though for very short bolts I drill and tap the hole to hold it. Backing the bolt out tends to force the burr outwards, which makes it easier to sand off on the belt or drum sander.
                        Doing it on a lathe- I've long wanted to build a cutoff attachment which might be a powered hacksaw. Lately I've been thinking that I'd like a disc with hacksaw teeth on it- it would be run at low speed and also be an attachment. You would position it where you want the cut, then it would lower like a chop saw basically. I'm thinking that I'd have guides set up to control the side to side flex (like a bandsaw) and they would be adjustable. Most often they would be set quite near the edge- just far enough back to clear the workpiece.
                        I use bi-metal bandsaw blades- no reason why a disc with similar teeth wouldn't do the job just as well. Where would I get such a disc?
                          When using the lathe to cut off or otherwise machine threaded stock or bolts, screws etc, I just use two nuts. Grip one in the three jaw chuck, thread the stock through the second one and install in the chucked nut. Adjust the stock so the desired cut off point is just outside of the second nut, lock the free nut in place and cut, face or machine as desired.
                          Jim H.
                            Another way....
                            Pretty sure i seen his name posting here, Frank Ford:
                            http://www.frets.com/HomeShopTech/To...rtenchuck.html
                            _
                              If you are getting serious,why not get a "cold saw" as it will solve a lot of other matters in the shop as well.
                              http://www.machineryhouse.com.au/S830
                              http://www.machineryhouse.com.au/Met...ldsaws-Ferrous
                              If I really needed one I'd buy it but with the small size stock I use and relatively few cuts I make I will stick to my 6 x 4 band-saw for now.
