another taper attachment Q
  • another taper attachment Q
    afternoon gang.
    I've gotten it in my head to finally make a taper attachement for the colchester student and have
    been doing some homework.
    I haven't quite laid it out on paper yet, but would like to bounce a question off the group.
    i'd like to make it so that I can go at least 15* either side of zero.
    (my first project will likely be one of those "unicorn" screw style log splitters.. smaller scale & electric ..
    always wanted to give one of those things a spin )
    if I make a classic T.A. to accommodate 30* swing, it appears that it'll get quite large.. i mean
    the stick-out behind the machine.
    are there any other designs / styles that might lend themselves better to larger tapers?
    It can be done, but you have to consider the length and diameter issue. Remember the cross is moving in the taper cutting operation.
    There is another way, but it is a bit more complicated, and the issues involved with the length and diameter still exist.
    http://www.practicalmachinist.com/vb...version-99359/
    Harry
      Check this taper turning device by another board member.
      http://bbs.homeshopmachinist.net/thr...r-turning-tool
      Jim
