Don't even need a 4 jaw for that, have faced many pieces larger than that in a 3 jaw chuck. Just watch your speed a little if the piece sits a little unbalanced.
And carbide can be used, haven't ever used anything else for these jobs.
Squaring up stock
It will work fine,just realise the side you face in the lathe won't be perfectly flat since a lathe faces slighly concave.
I've squared up several pieces with that method before I got my mill.
Try to keep things pretty well centered in the chuck - just to keep things
from getting too out of balance.
Squaring up stock
I have a piece of 1018 bar about 2" x 1.5" x 3/4". Is it OK to chuck this thing in the 4-jaw and clean up a 2" x 3/4" bandsawn edge? I don't need this to be glass smooth but I would like the edges to eventually be somewhat parallel and square to the faces. Anything I need to worry about, other than I probably shouldn't use a carbide insert?
I don't have a mill.Tags: None
