What's you're favorite cutting fluid
  • What's you're favorite cutting fluid
    ...for your lathe?
    My friend gave me a little bottle of a sulfur-based fluid, it works great. I get the idea it's pretty common stuff. What's it called? I need more.
    What other cutting fluids do you like? I'm just brushing the stuff on, I don't have a flood coolant system.
    WD-40 for cutting Aluminum
    Dark thread cutting oil for steel
    Crisco for tapping
      A9 for cutting, Drilling and Tapping Aluminum. Or under some conditions compressed air
      Dark Thread cutting oil for Steel
      If you had a flood coolant, which you don't, then one of many.
      Some like the mist systems, I can't stand the noise and the change in air quality.
        Swiss lube semi senthetic for flood on aluminum.
        Clean air blast for all steels - i hate misters, everything gets sticky.
        FSWizard - Free Online Speed and Feed Calculator
          For tapping I like AnchorLube G771.
            Bear Oil and Beeswax 60/40.
              Favorite cuting fluide
              My favorite... my old rapid tap can with 1,1,1-trichloroethane, always been the best...
              But today, I use Tap Magic with EP-Xtra...
                I don't use fluid, rarely I will use tap magic for threading.
                  I've got a Tap-Magic can, but I just keep refilling it with whatever cutting fluid is on sale in bulk. I think it's Tap-Ease in it right now. I like the small wax tapping sticks, good for applying to rotating cutters on the mill.
                  Gary
                  Appearance is Everything...
                    Used up the last can of Rapid Tap a couple of years back. Lately at work I've been using a heavy tapping cut about 2 to 1 with WD-40 in a Squirt Bottle. Save my Tap Magic for tapping in Stainless (316, 304 and Duplex Stainless Steels)
                      Mineral oil. My all purpose oil for EVERYTHING is crystal clear non smellinG mineral oil .I buy it at the farm supply store ,farmers use it to rub on horses .It cost about $8 dollars a gallon. You can use it all day long and when you shower at night there is no smell on your skin.I even use it for whay oil. However if I have a tuff tapping or threading job ,I still use the smelly sulfer based black oil.
                        Originally posted by Tony Ennis View Post
                        ...for your lathe?
                        Dark red cutting oil, pipe threading oil, etc.
                        http://www.amazon.com/Ridgid-70830-D.../dp/B0002YPMUM
                        http://www.truevalue.com/thumbnail/H...5/c/69/605.uts
                          For stainless drilling and tapping I love castrol moly-dee. JR
                            The blood of my enemies. Oops, sorry. Wrong - I was thinking of the best blade quenching fluid.
                              My favorite for small taps is castor oil. Clean, the smell is not bad, and the torque required is much less than it is for Rapid Tap.
                              Neat's foot oil is about as good as castor oil, but smellier. NF oil is great when you've got a dull drill down a deep hole and it's squealing and seizing up. It's amazing how it will reduce torque and allow you to finish the hole.
                              Yah, I know TD, I'm not a REAL machinist, I'm allowed to do stuff like this.
