Wish't I'd thought of that----------
  • Wish't I'd thought of that----------
    --G
    So what are we looking at, here?
      Obviously, they're headers. The pieces must be used to model the shape for custom made headers. Pretty slick but how do they keep them from moving?
        I've seen it done with pvc on exp aircraft. Someone had a good idea.
        country, in easy stages."
        ~ James Madison
          I've done that with cut up /heated and bent abs plumbing for a bike exhaust, only a twin, though! It's a good way to make sure of clearance around oil filters, stands etc before committing to metal, specially when it's pre-formed stainless bends... Too pricey to get wrong!
          Brilliant idea, though - are the clip-togethers expensive?
          Dave H. (the other one)
          Rules are for the obedience of fools, and the guidance of wise men.
          Holbrook Model C Number 13 lathe, Testa 2U universal mill, bikes and tools
            That's a great idea! wish I had them when I was making my set of headers up?
            Wonder what the cost is?
            Sid
              That is a slick solution, great invention, thanks for posting this.
                Not too bad price wise. Though the cheapos here might think so. Match the standard raduiis that you can bends. Or you can use it to layout the bend lengths and angles for machine bending.
                  Won't they melt when you fire the engine up ?
                    + 3 on posting this...http://www.jefflilly.com/fabrication...r-fabrication/ an example of a build...
