Anilam Wizard 211 Linear Encoder Replacement Cable?
  • Anilam Wizard 211 Linear Encoder Replacement Cable?
    I have an Anilam Wizard 211 2 axis DRO and the Axis 1 readout doesn't change when I move the table. Axis 2 works fine. There are two areas on the cable that look like they've been ridden hard and hung up wet so I've been looking for a replacement (Anilam part number 36000592). I can't find any.
    Do I have to replace the whole encoder or can I just replace the cable?
    Or should I try to find the short in the cable and just fix that? It's got a metal wrap around it so it could get ugly.
