Drive Pins
  • Drive Pins
    I am looking for 12 drive pins ( look like a rivet ) they hold the selector plates on the QC gear box. They are 1/8 in dia. For a south bend lathe
    Thanks
    GEP
    Try McMaster Carr, they should have them. Bob.
      I looked there could not find them any idea what they call them
        You're close with "drive pins" but most call them "Drive Screws".
        Motor repair shops usually have have a supply. Since you only need a few, you might ask them if they'll sell (most likely give) you some.
          Drive screws and screw nails for whatever reason???
          http://www.mcmaster.com/#drive-screws/=lzbe9i
            Thank you all
            I fund them at Mcmaster. All came out good exept one had the head break of do to rust. Any recommendations on how to get the shank out.
              Drive screws are hardened so drilling them out usually doesn't work. The best chance of removal is if they're located in a thru hole, and therefore, one can drive them out from the back using a punch.
                All in a name.
                Over here they are known as hammer drive screws or pins
