Coal
  • Coal
    I just was given about 100 lbs of the highest quality anthracite forge coal. Now what do I do with it?
    Save it for December 24th?
      Pressure, lots of it. Wait!
      Share with me.
      Make it fit.
        Build a forge, of course!
          Simple ...... put it on Ebay (i piece at a time) and call it "rare, valuable prehistoric fossiles", keep the price low (about $20.00 a piece) and jack up the shipping to Cost + $50.00 handling fee.
            Should be good for box hardening. A bit expensive to ship Paul but you are welcome to drop by and have some.
              Coal, wow! I spent all but the first 4 years of my entire working career doing maintenance for coal mines and that first 4 was spent in the mines working as a miner (scoop operator). Now I still buy 4 tons a year of the stuff (Bituminous however) to heat my farm house with. I have a few hundred ponds of Cannel coal (Candle coal to some) that I stowed away several years ago to use in a forge which I never got around to building.
                pretty well in monetery terms worthless too smal a quantity other than to make a few burgers smokin or what it will probably eat through your grill though LOL Alistair
                  The friend that gave it to me works up at Tumbler Ridge mine in a fairly high position but he still had to sign a release and promise that it would not be used in any coal burning appliance such as a coal stove. The worry is that it will eat through an ordinary iron stove in short order because of the temperature it generates. Coal is basically unavailable here. Nobody uses coal for heating as we have enough natural gas to last until the 30th century.
                    Years ago I worked in a blacksmith shop and we only used bituminous coal. I do not believe anthracite is your best choice.
                      We shall see if I even build any sort of forge. It will certainly work well for hardening.
                        I believe the live steam boys use anthracite coal, not sure, but unless you can get more, 100# isn't going to last long in a forge and then you have made something that can't be used again.
                          Yup, smiths prefer metallurgical grade (i.e., low sulfur) bituminous. The hard coal has higher btu content, but it doesn't coke well, but it's excellent for heating.
                            I did some looking and I can order coal by the hundred weight from a local hardware store. Don't know the price though. From cruising a few blacksmith forums I find it is liked for the very high temperature and exceptionally clean burning. I want it for fueling a melting pot for aluminum rather than an actual forge so heat and clean is good. I don't have the arm strength to swing a hammer at all, not even for nails.
                              You can always get Rosanne Barr to sit on the coal, with that kind of pressure you'll get diamonds in no time.
