I need to make a control panel with some rotary switches to select a number. For instance, the first rotary switch would be 0-9 for the 10s place and the second rotary switch would be 0-9 for the 1s place to allow a selection of 00 through 99.
The tricky part is that I'd like a digital output, preferably 8 bit. Now I've got some ideas how I can do this piece-meal, but I got to wondering if there wasn't a pre-made unit that does this. I was thinking about similar devices I know there are both analog and digital rotary encoders; something that my CNC machinist friends are very familiar with.
So ... my question is: do they make a " 8-bit rotary encoder" that has well defined positions, instead of a continuously variable shaft? As a special bonus, I'd like this to be reasonably priced. I don't need to measure any precise rotation measurement, just an 8 bit output from 00000000 to 01100011. Other possibly acceptable alternatives would be something that reads out data on "two wire" communication like an I2C bus.
Thanks!
Thanks!
