Source for spur gears
  • Source for spur gears
    I am looking for a source for spur gears for a large mower.
    There are three gears in all.First one is a 12DP 49 tooth which drives a pair of 12DP 45 teeth gears.
    I have found plain steel unhardened 45 tooth gears,but the 49 tooth is a real odd ball.
    have you tried a supply house that carries Boston Gear?
      Gear makers are...
      Boston
      http://www.bostongear.com/
      Martin
      http://www.martinsprocket.com/
      Browning
      http://www.emersonindustrial.com/en-...s/default.aspx
      When I was working on several projects that required gears I went and downloaded all the catalogs so I could compare. During that process I found a surprisingly easily source, Amazon.
