Fine Feed
  • Fine Feed
    I am planning to build a fine feed and are looking at worm gears. I am planning to use a 160:1 ratio. What should the pressure angle of the gear be. Looking for suggestions.
    Thanks
    Whatever you can find and what fits your worm. What is this going in to?
      I have this wanna be mill a HF 42976 that does not have a fine down feed. I realy didnt want to mess with the machine but i had some one that practicly beged me to buy it. I also want to build a CNC out of it.
        I don't know if it was this same model mill, but I've seen discussion of just such a retrofit either on this or other forums.
        Do a Google search and you'll likely find the thread.
          There is a thread on CNCZone that looks interesting but cant get to it for some reason
            A fine feed if nice, but I found that a readout (DRO) is a better feature on the vertical feed if precise control is needed. I find I can hit it within 0.0005" with the original lever feed on my Unimat after I added a DI readout. I have also added a readout (caliper) on my full sized mill and it is more useful than the calibrated, fine feed dial.
            Make it fit.
              Paul
              Can i see a photo of your installation
                I would use planetary gears instead, so you can put it inline with your current dial and have it take up a little space.
                this one is 1:10 used in gas powered RC cars:
                http://www.ebay.ca/itm/Traxxas-Plane...ht_3238wt_1163
                  How could i turn the gears you recommend 90 degres the worm gear. Would the plastic center with stand the cutter pressure
                    Originally posted by GEP View Post
                    Paul
                    Sure. I am not sure which one you wanted so here are both:
                    This shows my Unimat readout which is not really digital, but uses a dial indicator.
                    And this one shows the digital caliper DRO on my Grizzly mill. I never got around to removing the internal measuring jaws on the caliper, but I strongly recommend it as the pointed jaws can be a hazard to your hands.
                    As I said, both of these make precise downfeeds much easier.
                    Make it fit.
                      Thanks Paul
                        Just want you to know i am backward my last name Paul
                          I was able to find the thread I was referring to earlier. Maybe it'll be applicable to your machine.
                          http://www.hobby-machinist.com/showt...hlight=hormier
                            Well, I must be inside out because Paul is my middle name. It started with my grandfather and I do not know the reason. My father was also called Paul. My wife put her foot down and our son goes by the first name, Edward. I guess he is the only straight forward one.
                            Make it fit.
                              Eward is a good name as well
