McLean Finger Plate Vise - Atlas 618
  • McLean Finger Plate Vise - Atlas 618
    In this post, "JFLingg , Atlas 618 Home Shop exists, 04/08/2012",
    I said I would post again when I made something besides a washer.
    From Live Steam Mag., April 1979, Frank McLean’s “The Beginner’s Column”, a finger plate vise.
    “Plate” is from part of a garage door opener, bolts are cut-down rethreaded metric head-bolts, nut from mystery hot-rolled, washer from an old bolt found on old mine site.
    Looks odd, works good. The best thread may be 65%, O.D. thread, single point 3/8-24, I.D. nut bored and tapped, plate drilled 11/32” and tapped.
    I am working on an Elmer Verburg simple wobbler. I got lots of tips, hints, and good stuff from HSM mag and website.
    Thank you all,
    JFLingg
    JFLingg @ 25 miles east of Colorado Springs, Colorado
    A spring around the right hand bolt under the top plate might make it handier to use. Looks good!
      Nice work. This will become one of those little tools that may sit in your toolbox for years and will being a small smile to your face every time you use it. Thanks for posting.
